Create Your Own Shortcuts
What is anyone using to create your own Pro Tools shortcuts in Windows 10? I read a couple comments about this recently, but can't recall for sure the content.
PT 12.5 Windows 10
"Modern manufactured music is like art they sell at a furniture store." http://www.weddingmusicproject.com/ http://www.weddingmusicproject.com/w...music-samples/ http://stevemillikan.com/ |
Re: Create Your Own Shortcuts
Try AutoHotkey.
Thanks Weed, I'll check it out.
I tried AutoHotKey, and got it to work fine in other apps, but for some reason, it doesn't seem to work for me in PT. The macro just doesn't play in PT.
Questions: 1. Can anyone provide a simple AHK script that works in PT 12 that I can model my scripts after? 2. If AHK isn't the best choice, what's better? Last edited by wevets; 04-30-2016 at 03:58 PM. |
What kind of shortcuts are you needing? There are tons of them already
The shortcut I want doesn't seem to exist in PT the way I want to use it.
I do voice over work, and in particular, audio books. I need to insert room tone in spaces between sentences to hide the noise breath noises. I have room tone recorded which I put on the clip board. I mark a breath by selecting it with the mouse, then hit Ctrl+Alt+v to just fill the marked breath with room tone from the clip board. The move takes a lot of hand motion. I could save a lot of time over a long bit of text if I could do the whole operation from my mouse. So I'd like to have a button on my mouse dedicated to insert the Ctrl+Alt+v string into the PT character queue. I have worked this out for inserting the string from a mouse button into apps like notepad and word, etc, but the string is just not seen by PT using this method. I've tried using AHK, triggered by a mouse button, to inject the key strokes into PT, but no joy. Any ideas? |
I have not tried it on PT, but maybe try a Wacom tablet in place of the mouse. I use one in DP and there are a couple of different ways you can program keys strokes. Takes a little getting used to though. Search the DUC or Gearslutz for threads on the Wacom tablets.
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
YourChoiceOfMouseButton:: WinMenuSelectItem, Pro Tools, , Edit, Paste Special, Repeat to Fill Selection return " PT does not accept anything from AHK that contains Alt or Start or AltGr for some reason. The above code avoids the shortcut with Alt and recalls from the menu directly. Another way to do what you want to achieve. Cut the breaths with "X", have a long (looped) roomtone track beneath the narration track (muted during editing), when finished editing : object-select all edited clips and start-drag over the roomtone track.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
I have a couple shortcuts I would like (just moved from PT7 on Mac to 12 on Windows). For starters:
Hide/Downsize Pro Tools Pitch n' Time Interface from Audiosuite AutoTune interface from Audiosuite Export File. There is a probably a way to highlight a file and quickly export it, but I haven't figured it out yet, and if there isn't, I can't imagine living without one, although I guess bounce to disk offline isn't too bad.
Clicking a clip and Ctrl Shift K isn't that bad, or ?
How to create my own Pro Tools shortcuts? | Detlef Brockmann | Pro Tools 11 | 4 | 01-10-2014 01:09 PM |
A-Z keyboard shortcuts for GROUA-Z keyboard shortcuts forPS in the SECONDS ID group.. | jessedtf | Pro Tools 10 | 6 | 10-24-2012 09:42 AM |
Want to create new PT shortcuts. Tell me how. | pcmusicpro | Windows | 2 | 07-11-2012 11:44 AM |
shortcuts to create and copy pathes | tpless | Pro Tools TDM Systems (Mac) | 0 | 01-12-2008 11:06 AM |
How do I create desktop shortcuts in 10.3.7? | ProToolsguy56 | Post - Surround - Video | 1 | 02-05-2005 12:23 AM |
