Old 04-29-2006, 12:01 PM
Rajnesh Rajnesh is offline
Default Slowing down Audio from 24fps to 23.98fps...
Hi All,
I have film originated Audio at 24fps, and I'd like to slow it down to 23.98fps so that I can author NTSC DVD's.
Could you tell me how to accomplish this?
Thanks in advance for your time.
Regards,
Rajnesh
Old 04-29-2006, 05:13 PM
minister's Avatar
minister minister is offline
Default Re: Slowing down Audio from 24fps to 23.98fps...
best way to do this is with an external clock, a sync i/o and engage .1% pull down. you can also use a USD.
another "down and dirty" way, if you don't have the above is :
create a new 23.97 (or 29.97) 48k session. import the 24fps tracks and apply SRC to them. for SOURCE SR select 47952Hz as your source. this will pull it down (make it longer) to 48000.
can we make this a sticky?
hey David Sandwisch! we need to finish Book!
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 04-30-2006, 11:28 AM
Thanks for the info. I just received some more information that I thought would be nice to Share:
Apple's SoundTrack Pro has a feature inbuilt called the "Stretch Tool" which they say will do this Stretch without Changing the Pitch.
Apparently, there's also an OpenSource Sound Editor called Audacity that one can use.
Regards,
Rajnesh
Old 04-30-2006, 11:48 AM
minister's Avatar
you can also use PT's TC/E AudioSuite Plug for this.
have you listened to the effect of "Stretch Tool"? over the course of a program, does it sound good?
Tom Hambleton CAS
IMDb
-Starcrash
HTML code is On
Converting 25 fps to 24fps Audio Kade B Pro Tools TDM Systems (Mac) 5 01-02-2012 07:05 AM
24fps to 23.98fps PT's Session - deliverables D'Animation Post - Surround - Video 12 10-11-2011 06:05 AM
Slowing down Audio from 24fps to 23.98fps (Origin: Rajnesh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-30-2006 11:35 AM
slowing down audio in PT 6 takeouttonys 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-17-2004 02:00 PM
30fps to 23.98fps, pull up audio .01%????? actualsizeaudio Post - Surround - Video 1 07-28-2004 02:00 PM
