dae error -9060 on PT 8.0.3 and W7 64bit
Hello.
I'm plagued with DAE error -9060 messages after installing Windows 7 and PT 8.0.3. Running XP on the same system (but with PT8.0.1cs1) never gave me these 9060 error messages and ran smoothly. I get the messages after either using stock PT AudioStuite or RTAS plugins. Simple AudioSuite plugins like Gain induces there error messages. It's not critical, but very annoying. PT stops playback. I have to click away the error messages, and start playback again. Then it works. But using the AudioSuite (gain, normalize, eq, etc) again gives me the error message Anybody else have these problems ? SiSoftware Sandra Computer Model : Gigabyte EX58-UD3R Workgroup : TEXAS Host Name : t10 User : root Processor Model : Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz Speed : 2.8GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 8 threads sharing Computer Mainboard : Gigabyte EX58-UD3R BIOS : Award (Phoenix) FD4 09/01/2009 Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 6GB DIMM DDR3 Chipset Model : Giga-Byte X58 I/O Hub Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Chipset Model : Giga-Byte Core Desktop (Bloomfield) UnCore Front Side Bus Speed : 2x 2.4GHz (4.79GHz) Total Memory : 6GB DIMM DDR3 Memory Bus Speed : 2x 532MHz (1GHz) Memory Module(s) Memory Module : OCZ OCZ3P1333LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) Memory Module : OCZ OCZ3P1333LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) Memory Module : OCZ OCZ3P1333LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) Video System Video Adapter : ATI FireGL V3600 (120 SM4.0 600MHz, 256MB DDR2 2x500MHz, PCIe 1.00 x16) Graphics Processor Adapter : ATI FireGL V3600 () Storage Devices Kingston SSDNow 64GB 64GB (SATA300, NCQ) : 60GB (D:) SAMSUNG HD322HJ (320GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 298GB (E:) (F:) CORSAIR CMFSSD-128GBG2D 128GB (SATA300, NCQ) : 119GB (C:) Optiarc DVD RW AD-7200S (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (G:) Logical Storage Devices music (D:) : 60GB (NTFS) @ Kingston SSDNow 64GB 64GB (SATA300, NCQ) data (E:) : 220GB (NTFS) @ SAMSUNG HD322HJ (320GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) xp (C:) : 119GB (NTFS) @ CORSAIR CMFSSD-128GBG2D 128GB (SATA300, NCQ) image (F:) : 78GB (NTFS) @ SAMSUNG HD322HJ (320GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) 3.5" 1.44MB (A:) : N/A Optical Drive (G:) : N/A @ Optiarc DVD RW AD-7200S (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Giga-Byte LPC Interface Controller LPC Legacy Controller 1 : ITE IT8720F Audio Device : ATI (AMD) HD Audio Codec Audio Codec : ATI (AMD) AA01h Disk Controller : Giga-Byte 4 port SATA IDE Controller Disk Controller : Giga-Byte 2 port SATA IDE Controller Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1 : Giga-Byte USB UHCI Controller #4 USB Controller 2 : Giga-Byte USB UHCI Controller #5 USB Controller 3 : Giga-Byte USB UHCI Controller #6 USB Controller 4 : Giga-Byte USB EHCI Controller #2 USB Controller 5 : Giga-Byte USB UHCI Controller #1 USB Controller 6 : Giga-Byte USB UHCI Controller #2 USB Controller 7 : Giga-Byte USB UHCI Controller #3 USB Controller 8 : Giga-Byte USB EHCI Controller #1 FireWire/1394 Controller 1 : Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit Ethernet NIC (NDIS 6.20) (Ethernet, 1Gbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 5.1 |
Re: dae error -9060 on PT 8.0.3 and W7 64bit
As you can se I'v only got internal disks. System (W7) + programs are on the 128 GB SSD disk. I'm recording to the 60GB SSD disk. Could this be a problem ?
I don't know if I"ll be of any help to you, but the only times I've had a 9060 error was when I had a corrupt audio file or corrupt fade file.
Do you have a non-SSD to record to just to compare?
https://www.thirdeyerecording.com/ |
Yes, but as I said this was no problem with excactly same setup on XP and Pt 8.0.1cs1.
Thanks for answer thow. |
What worked to solve this issue for me was to delete the database and prefs. But that alone was not enough. Deleting the WaveCache.wfm and the Fade Files folder from the session that first gave me problems was the solution. Now all sessions open as should. Hope this helps someone.
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7 |
I'm having a similar problem. I've upgraded my pc to a AMD II x2 running Wins 7 and running a M Box 2 Mini. Everything seemed to be working fine until I loaded in the free BFD Lite. It worked for while and then started saying the DAE was low on memory and showing error 9060! It also effects a couple of other plug-ins stopping them from running but all others are fine. Surely Avid must sort this out????
Any ideas? OS Name Microsoft Windows 7 Home Premium Version 6.1.7600 Build 7600 Other OS Description Not Available OS Manufacturer Microsoft Corporation System Name PC System Manufacturer BIOSTAR Group System Model A780L System Type x64-based PC Processor AMD Athlon(tm) II X2 250 Processor, 3000 Mhz, 2 Core(s), 2 Logical Processor(s) BIOS Version/Date American Megatrends Inc. 080014, 03/11/2009 SMBIOS Version 2.5 Windows Directory C:\Windows System Directory C:\Windows\system32 Boot Device \Device\HarddiskVolume1 Locale United Kingdom Hardware Abstraction Layer Version = "6.1.7600.16385" User Name Malcom-PC\Malcom Time Zone GMT Daylight Time Installed Physical Memory (RAM) 3.00 GB Total Physical Memory 2.75 GB Available Physical Memory 2.07 GB Total Virtual Memory 5.50 GB Available Virtual Memory 4.40 GB Page File Space 2.75 GB Page File C:\pagefile.sys |
Does anyone know what this error message means. ERROR DAE 9060 | boabyd23 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-18-2009 11:41 AM |
DAE Error -9060: Region Match Selection Error ... | PatrickJ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-04-2005 04:36 PM |
DAE 9060 Error | bassplayer01 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 02-11-2005 09:22 AM |
DAE 9060 error | jpd52 | Pro Tools TDM Systems (Mac) | 4 | 12-02-2003 08:58 PM |
DAE Error -9060 | Datus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-16-2002 11:31 AM |
