Old 05-27-2011, 01:33 PM
DaleB DaleB is offline
Default Ethernet hub necessary? Switch?
Hi. I have a new D-Command main unit and 16 fader module. Yay me. I rule. Or, rather... I would if both units were working. But they're not.
I'm connecting them to my MacPro tower, which has two ethernet ports. Do I use BOTH ethernet ports? (when I've done that, there's no communication with the fader module.) Or do I get an ethernet hub and plug it into ONE of the MacPro's ports? And would an Ethernet SWITCH work just as well?
-dB
Old 05-27-2011, 01:35 PM
Default Re: Ethernet hub necessary? Switch?
Oh... and yes... I have been declaring the units in the Peripherals dialogue box. As best I can.
Old 05-27-2011, 01:49 PM
Also... does anyone know what the tiny Ethernet "dummy plug" is for that came with the D-Command? Some sort of terminator. But where on earth would that go?
Old 05-27-2011, 03:27 PM
Craig F Craig F is offline
One tower port for D-Com the other for facility network
yes, you need a hub or switch so both units can be on the name NIC (Network Interface Connection)
that plug is a loop back plug for special testing, you'll probably never need it but don't lose it (that why you'll never need it, Murphy)
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 05-29-2011, 01:26 PM
That did the trick. I found an old ethernet hub in my basement (my "packrattiness" finally pays off!) and plugged both main and fader units into ONE of the MacPro ethernet jacks and voila!
(Thanks for the info on the purpose of the loopback plug too.)
MC Mix & Control on MacPro - wich Ethernet Switch? nstu Artist Series 6 12-20-2011 12:17 PM
what ethernet switch are you using for multiple MC units on a Mac snake doc Artist Series 5 07-07-2010 03:57 PM
C24 and Ethernet Switch MusoPro ICON & C|24 1 08-30-2007 04:52 AM
Control 24 Ethernet Switch MusoPro Post - Surround - Video 4 08-30-2007 03:02 AM
Crossover or straight-thru for ethernet on switch? satsi ProControl, Control|24, Command|8 1 03-23-2004 11:01 PM
