Old 08-29-2007, 05:29 AM
MusoPro's Avatar
MusoPro MusoPro is offline
Default Control 24 Ethernet Switch
Hey Guys,
Up until now I've been using my C24 connected directly to my Mac G5. I am now in a situation where I need to be hooked up to the internet at the same time. Is it just as easy as getting a Ethernet Switcher and hooking it up with both the C24 and the DSL modem connected to my Mac. I have a session tomorrow where I need to run the set up. So any help is really appreciated.
I'll be using this in connection with Source Connect which was in one of my previous posts.
All the best,
Mitch
Best
Mitch
MacPro 2.44 8 Core
Mac OSX 10.10.5
PT 12.7
HD Native
SyncHD I/O
HD I/O
MIDI I/O
C24
Aja LiHi
Surround Setup
Old 08-29-2007, 12:16 PM
Craig F Craig F is offline
Default Re: Control 24 Ethernet Switch
yes, it should be that easy
if your G5 is of the last of the run you should have 2 ethernet ports on the G5
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 08-29-2007, 01:54 PM
Stylin' Audio Stylin' Audio is offline
A switch works fine with the C24. I just have a cheap LinkSYS 5 port model and have had no troubles yet, even with another computer using a port to shove files to the FTP. Setup is as easy as plugging it in..how often can you say that!
I have no experience with Source Connect in that setup though, so ultimately YMMV!
Colin Van Hattem
Noizemaker Productions
Old 08-29-2007, 08:39 PM
Eric L Eric L is offline
The Control 24 requires a "crossover" ethernet cable when connected directly to the computer. However, most computers are smart enough to internally swap the pins if a regular cable is used.
A switch, should be smart enough to know to reverse the cable if you just use a regular cable.
However, we ran into a problem when one of the MacPro ethernet jacks was connected to a network and the other to the control 24 directly, without a crossover cable. It seems that the internal crossover function of the NIC is disabled when two different connections are made at the same time.
So we had been using a "regular cable" with the single NIC G5. When we upgraded to the dual NIC Macpro, we had to make a crossover cable.
So, YES, it should work. But if it doesn't, this is one possible reason why.
Eric Lalicata C.A.S.
Supervising Sound Editor
Re-Recording Mixer
Anarchy Post
1811 Victory Blvd
Glendale, CA 91201
818-334-3300
www.anarchypost.net
Old 08-30-2007, 02:02 AM
MusoPro's Avatar
Great! That was to easy!!!!
All the best,
Mitch
Best
Mitch
MacPro 2.44 8 Core
Mac OSX 10.10.5
PT 12.7
HD Native
SyncHD I/O
HD I/O
MIDI I/O
C24
Aja LiHi
Surround Setup
HTML code is On
MC Mix & Control on MacPro - wich Ethernet Switch? nstu Artist Series 6 12-20-2011 11:17 AM
Ethernet hub necessary? Switch? DaleB ICON & C|24 4 05-29-2011 12:26 PM
what ethernet switch are you using for multiple MC units on a Mac snake doc Artist Series 5 07-07-2010 02:57 PM
C24 and Ethernet Switch MusoPro ICON & C|24 1 08-30-2007 03:52 AM
Crossover or straight-thru for ethernet on switch? satsi ProControl, Control|24, Command|8 1 03-23-2004 10:01 PM
