Old 01-24-2018, 06:36 AM
WilliebSR WilliebSR is offline
Default To Slave or Not to Slave.. that is the ?
I used to run a slave puter and used Vienna Instruments to link. Then processors got faster and I went to single with outboard raid for some sample libraries. The challenge now is my sample libraries are getting too big.
Now that the i7 processors have MOBO that accept Thunderbolt I'm thinking of going that route.
Any experiences you'd like to share? Advice?
Thanks in advance.
my siggy is a bit out of date
Win 10 64bt; PT12.5 G'byte Z87X-UD4H; i7-4770K; 32 GB DDR3 1600MHz;
Nvidia GTX 770
; 2X SSD 840 EVO 500GB; 2X SG 2TB ; 1X WD Blk 1TB ; 42" HDMI x3 & LG 30" Wide mon
Apollo16 x2; 11 Rack; AxeFX; TwoNotesStudio; Line 6 Pod;
Artist Control, Mix, Transport; Control 1; Axiom49; NI Komplete Control
Amphion ONE15; Focal A50; HR824; and more;
Old 01-24-2018, 02:38 PM
Default Re: To Slave or Not to Slave.. that is the ?
Are you doing a new build? If so take a look at putting nvme storage on pcie slots provided you can get the sizes you need for those large libraries. It'll be the fastest option for drive access. It won't be cheap - that's for sure.
While I loved it when I ran a client/server setup with VEPro 6 there's something to be said for the simplicity of having one machine especially when it comes to system maintenance time.
Jack
QAPLA!
Old 01-24-2018, 09:40 PM
Thanks for responding. Yes, I'm doing a new build.
Going to try to address additional monitors, more ram, and more sample streaming for larger templates all in one fell swoop.
Good idea on NVME. I'll check and see if I can figure out how to compare that speed to the thunderbolt's on the pci bus. Had already decided to use an M.2 for the OS. Have that on the current system, and as I recall that resulted in some noticeable improvements.
I'm liking the looks of the i7-8700k because it adds two more cores and its way cheaper than the extreme versions with that many cores, but the motherboards available look to be focused on gamers. Seems like more attention to having blinky lights than data transfer.. The exception is the ability on some MOBO to have a thunderbolt card and the additional pcie lanes... (which is good????)
I did find one board that had an additional two front SATA ports which seems important because on most boards when you add M.2 you lose access to some of those ports.
So... bigger drives on the SATA bus OR... some type of off board box that connects via thunderbolt. OR M.2 drives on a pci card OR some combination
I'm leaning toward the combination plan. I was posting to make sure I wasn't shooting myself in the foot. Hoping that some of you guys have already tried something like this, and wouldn't mind chiming in.
Nvidia GTX 770
slave another pc? mattytoldhatty Windows 3 12-16-2011 04:20 PM
korg d1600 being slave a slave to pro tools sbag MIDI 0 04-12-2007 06:50 AM
001 As Slave? Orange Worker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-06-2005 06:20 AM
slave ICE MIKE MIDI 0 10-05-2003 01:21 PM
PT as slave? carson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-09-2001 03:44 AM
