Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 12-18-2017, 10:38 AM
audioman1973 audioman1973 is offline
Default Re: Win10 Pro - Class Compliant Hardware Problem - Midi
After it is recognized in Device Manager you will see it as one of the midi controller choices in Setup>Midi Devices in Protools without having to do anything in Midi Studio Setup if you are using the USB cable from the keyboard to the computer. I only have to use MSS for my other keyboard which is a Roland RD-700 and is ran through the Motu 128 interface using midi I/O cables.
Pro Tools Ultimate 2023.9. Mac Studio M2 128GB Ram 24 Cores 4 TB HDD. 2 Universal Audio Satellites. Lynx Aurora N.
Old 12-18-2017, 02:52 PM
My Axiom 49 is working fine.
Go into Device Manager
Right click it
Browse my computer for driver software
Let me pick from a list of available drivers on my computer
and see if anything shows up.
Mine is just "USB Audio Device" driver
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 12-19-2017, 06:51 AM
The class compliant driver in Windows 10 is very finicky. I have noticed several times my Axiom Pro 61 not being in Device Manager or in the Protools Devices box after first booting up Windows. The quick and easy fix is to just unplug the usb cable from the back of the Axiom and plug it right back in. It causes Windows to then recognize it for me every time. It’s a pain in the rear sometimes but it always works.
Old 12-19-2017, 02:57 PM
Neil H Neil H is offline
I presume you've seen this in your searching?
https://c.getsatisfaction.com/m-audi...dows-10-64-bit
Sent from my G8141 using Tapatalk
Pro Tools 2019.5 Ultimate
Windows 10 Pro
Join the Facebook Pro Tools Windows User Group
Old 12-19-2017, 03:28 PM
YYR123's Avatar
YYR123 YYR123 is offline
Neil,
Hey what's up. Yes I have seen that thread.
I also tried steve's suggestion to no avail, I seem to have a lame duck issue here.
So I just installed this package on a WIN7 system and then searched the drivers in Explorer. I will try to manually install them and see what that gets me....The guy from Maudio said it was compatible...so who knows.
I still ordered the fast lane...and will be using that long term but If I could get some more things done before the holidays that would be nice.
Daniel
  #16
Old 12-19-2017, 03:37 PM
Originally Posted by YYR123 View Post
Neil,
Ah OK cool guessed you may have but thought I'd post it up just in case
Windows 10 Pro
  #17
Old 12-19-2017, 03:45 PM
seriousfun seriousfun is offline
Right click on the driver .exe, choose "Run as Administrator" at the bottom. Then click on the Compatibility tab, choose under Compatibility Mode "Run this program in compatibility mode for Windows 7." Click apply, and hopefully the driver will install.
  #18
Old 12-19-2017, 03:51 PM
If you got a Windows installer disc, you could also try having it search that for the driver.
pro-tools-pc.com
Intel I7 9900k
Win 10
  #19
Old 12-19-2017, 04:23 PM
Actually just had a thought make sure to disable driver signing when doing the install as that's got pretty aggressive with older drivers recently too.
Windows 10 Pro
  #20
Old 12-19-2017, 04:37 PM
YYR123's Avatar
Sounds good let me check and try a few things
I will report back
Daniel
MBOX and class compliant mode for Ipad use Film16 FireWire & USB Audio Interfaces (Win) 2 07-26-2013 11:34 AM
PT 7.0 file non compliant with 6.4 wtf!! Mot2000x 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-21-2006 09:09 PM
Is my exp. chassis PCI 2.1 compliant? Guy Staley Pro Tools TDM Systems (Mac) 2 03-18-2002 12:35 AM
Digi Responds With Class to C24 Problem tomhartman Pro Tools TDM Systems (Mac) 0 02-14-2002 10:49 PM
Digidesign *COULD* have a World Class Midi/Audio application!!!! Lee Blaske Pro Tools TDM Systems (Mac) 27 12-13-1999 09:37 AM
