Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 08-23-2018, 07:19 PM
its2loud its2loud is offline
Default Avid Matrix Mic Pre clicking
Posting a question to any users of the Avid Matrix with the A/D card with mic pre option.
Is anyone experiencing clicks or pops when increasing or decreasing the mic pre gain? We have four units that all experience this issue when adjusting.
Wondering if this is intentional (not sure why) or a circuitry defect.
Thanks.
Old 08-23-2018, 09:41 PM
LDS LDS is offline
Default Re: Avid Matrix Mic Pre clicking
Is anyone experience clicks or pops when increasing or decreasing the mic pre gain? We have four units that all experience this issue when adjusting.
Thanks.
I haven't used the Matrix, but clicking is pretty common in a lot of devices when increasing gain. I'm pretty sure the Avid Pre does the same thing, as do a whole slew of digital mixing desk preamps, etc. From my understanding it is the result of the digital gain control, which is incremental rather than continuously variable like in fully analogue circuits. The PGA2500 mic preamp chip is a prime example, where the clicks can be minimised by design but not necessarily removed entirely. It appears in a whooooole lot of audio interfaces being made today.
Even in higher end designs, to achieve high levels of matched digital gain control, relays are pretty commonly used. It wouldn't surprise me if the clicks and pops are just a byproduct of the design.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Old 08-24-2018, 07:24 PM
EddieJones's Avatar
Yes, it's the relays. This is to achieve the best quality we can. (You shouldn't be adjusting the gain whilst recording)
Accurate Mic-pres with relay gain system
The MTRX mic pre’s have an outstanding performance with an equivalent input noise below -130 dB. A resistor-based gain step circuitry with relays ensures that no un-linear distortion is added to the sensitive microphone signal when amplified. Each 0.1 dB gain step is digitally compensated for an inter channel accuracy of 0.1 dB.
Old 08-24-2018, 07:27 PM
Ha ha. Thanks Eddie. Not sure if that’s good news or bad news. So, I’m not supposed to adjust the gain on the fly when recording ADR and the actor goes from screaming to whispering in a scene? Is there no way to fix this gain structure so it doesn’t happen? Riding mic gain is normal part of record dialog for animation or ADR.
Old 08-24-2018, 07:29 PM
EddieJones's Avatar
This is a standard design in high-end mic pres. It has 130db headroom...you could use the fader.
Old 08-24-2018, 07:32 PM
Fader? I’m using the S6 fader to adjust gain now. Just trying to figure out the best way to minimize clicks. I get the circuitry and the relay factor.
Please clarify what you mean by “use the fader”.
Old 08-24-2018, 07:36 PM
EddieJones's Avatar
You would set the Mic gain so that the absolute Max signal hit 0db (or -1) digital. Then use the fader to ride gain for cues. With some compression/limiter if needed.
Old 08-24-2018, 07:37 PM
EddieJones's Avatar
If there were obvious scenes where you knew there was going to be whispering etc then you would preset the Mic gain before the take.
Old 08-24-2018, 07:44 PM
Are you referring to using an aux fader in ProTools? If so, I get that. That’s how we record now. But when you’re using compression on said aux feeding an audio track and want the incoming signal to have more gain to the aux, sometimes you need to adjust the pre gain. Just a matter of logistics. Not arguing semantics here. Just want to know if reducing the clicks is possible. I get the pre has tons of headroom. That’s great.
Every analog mic preamp in existence did not exhibit clicks and pops when increasing or decreasing gain. Not sure if that makes it acceptable for
A/D preamps to exhibit opposite behavior.
Appreciate your input.
Old 08-24-2018, 07:47 PM
That’s not always an applicable way things operate in the real world unfortunately.
M/S matrix, how do I set this up? thultmark Pro Tools 12 6 01-11-2016 08:47 AM
SSL MATRIX and MORE PWrightIII Buy & Sell 0 01-02-2016 12:32 AM
Matrix 1000 + Pt 8 alessio MIDI 1 09-05-2009 03:46 AM
M-S matrix tirt1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 10-01-2002 08:30 AM
where is the matrix ? sandman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-12-2001 12:39 AM
