Old 04-04-2019, 02:48 PM
Cayce Cayce is offline
Default Pro Tools won't Playback thru PreSonus StudioLive 24R
I've just installed a PreSonus StudioLive-III 24R rack mixer, replacing my StudioLive 16.0.2 console, which I've outgrown. I like the idea of the rack config because I don't mix live, only needing a 24-input interface to use with Pro Tools.
Pro Tools had no problem working with the 16.0.2 console, but I can't get it to playback through the 24R. PT sees it in the Hardware Setup, Playback Engine, I/O setup is showing 64 channels (32 stereo pairs) in both the input and output, compatible with the I/O in the 24R. The only thing I can get out of the 24R, though, is what's coming in through the inputs. Nothing from Pro Tools.
If anyone has had any experience with this interface and can lend a hand, it would be appreciated.
Thanks.
Pro Tools Studio, 2023.3.0
Mac OS: Ventura 13.4
System: Mac Studio 2023, Apple M2 Ultra, 128GB Unified Memory
2TB Internal SSD
Apple Studio Monitor, 27"
3 External Monitors: 27", 27" & 65"
Apollo X8P Mixer Interface
PreSonus 32R Mixer Interface
Old 04-04-2019, 03:24 PM
Default Re: Pro Tools won't Playback thru PreSonus StudioLive 24R
Are you reading and following the good documentation in "Using Your StudioLive Mixer as an Audio Interface with Universal Control"?
Start with getting one thing working at a time. Starting with a new empty session created with that playback engine selected (to be sure you get all the correct IO path names) and playing back something pre-recorded that you know is good, or just use signal gen.
If the playback engine is selected and you have output on a track going to the correct IO path then a likely suspect should be the return routing within the StudioLive. Are you outputting to the Main Digital return or something else? Make sure the IO paths in Pro Tools look correct and Delete and Default them if not.
Old 04-04-2019, 04:30 PM
Thanks, Darryl;
Interesting you mention that, because it's been a point of frustration for me. The paragraph you're referring to in the "UC Surface Reference Manual" says:
"Using Your StudioLive as an Audio Interface with Universal Control
Reference Guide: This guide describes the features and functions
Universal Control as well as how to use your StudioLive mixer as
an audio interface with your favorite DAW application."
This sounds like it would explain everything, but there seems to be no such document as the "Universal Control Reference Guide" it refers to. I've looked under every rock, have downloaded a half dozen other reference and user manuals associated with the 24R, but one by that name seems to be hidden pretty well.
I'd love to have it if you know where it is.
2TB Internal SSD
Old 04-04-2019, 04:37 PM
All documentation is here: https://www.presonus.com/products/St...-24R/downloads
Old 04-04-2019, 05:06 PM
ok... that's the one... and I see where I screwed up...
I thought Universal Control Reference Guide was the name of the manual, and that Using Your StudioLive as an Audio Interface (with) was just explaining what the guide named Universal Control Reference Guide was for.
I was barkin' up the wrong tree... dang...
Thanks again, Darryl.
2TB Internal SSD
Pro Tools 11 and Presonus Studiolive 16.4.2 Chefplaydrums13 General Discussion 3 12-03-2014 08:25 PM
Pro tools 10 and Presonus Studiolive 16.4.2 danwillmore Third Party Interfaces 13 08-11-2014 09:09 PM
Pro Tools 10 and Presonus StudioLive 24:4:2 David Every Windows 4 03-13-2013 02:06 PM
Picky: Pro Tools 10 and Presonus Studiolive Tim Mayock Windows 6 02-28-2013 02:34 PM
using presonus studiolive 16.0.2 and pro tools 10 jrbarraz macOS 1 08-01-2012 11:06 PM
