Old 11-11-2011, 01:11 PM
propower propower is offline
Default Input output delay compensation with 3rd party interface
Hey all,
If one uses a 3rd party interface (no avid interface) with PT10HD or PT10 w/ CPTK is there a place in the I/O or hardware setup boxes so that you can automatically compensate after a record pass for the input and output delays of the interface? (On HD9 with 192 these are in the I/O setup pages)....
Thanks!
2017 27" iMac 3.8GHz i5, 1TB SSD
Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB
Musician: http://www.ivanlee.net/
Design Engineer: http://www.propowerinc.com/resume.html
Old 11-11-2011, 01:31 PM
Default Re: Input output delay compensation with 3rd party interface
Nope. I/O Compensation after record pass is only present with HD hardware connected. Which I might add is now checked by default with Pro Tools 10.
Aaron Mulqueen - 001 HD Native
Old 11-11-2011, 01:46 PM
Wow...... that is a big bummer!
If I uncheck the "input and output compensate after record" boxes and do a loop test with a 192 (analog to analog) then I get 90 samples or so late for the recorded track (with no plugs). If this was third party I would have to manually nudge by the right amount after every record pass???? Yikes....... is there an easier way???
Thanks
Old 11-11-2011, 03:31 PM
Delay everything by the record pass delay.
Old 11-11-2011, 04:21 PM
Sorry... don't understand.......
Old 11-11-2011, 07:09 PM
TOM@METRO's Avatar
And vote.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 11-11-2011, 07:40 PM
Maybe what you meant is to enter the in/out delay in the User part of the delay compensation (at the bottom of every track)....... I can see this would work but I couldn't figure a way to enter this on a range of tracks only one at a time....... Again tedious but not impossible. Would be a lot slicker to have a way to make this automatic ...... As long as we are allowed to use other interfaces why not be able to simply enter the appropriate value........
As I see fro Tom's post..... others have been here before......
Thanks,
-Lee
Old 11-11-2011, 07:47 PM
Manual alignment forward or back is the only way just like a native system. Lee.
Old 11-12-2011, 12:09 PM
Well as it turns out this is mostly a non issue....... As long as the core audio driver correctly reports the recording delay it is correctly accounted for in Pro Tools................
http://duc.avid.com/showthread.php?t=288087&page=5
From DTS..... "Just to clarify - all devices that use ASIO or Core Audio driver should automatically report their delay via the driver to Pro Tool, which then compensates for that.
The only delays that should need to be compensated for are ones that have no way of reporting to Pro Tools directly - hardware inserts or devices in the recording chain. Most analog devices have zero delay and most external digital hardware devices have delays in the order of a few samples.
We are aware of the usability problem that is caused by not having user-definable record delay compensation and will look at ways to possibly improve this in the future."
Old 11-12-2011, 01:13 PM
"We are aware of the usability problem that is caused by not having user-definable record delay compensation and will look at ways to possibly improve this in the future."
That quote answers your question.
Input Delay Compensation? Alexmc1988 Pro Tools 10 2 11-18-2012 04:10 PM
Pro Tools 9 Delay and Delay Compensation on Aux Tracks and Bussing CNSound macOS 1 01-27-2012 11:10 AM
Sappire Pro24 DSP Interface and Pro Tools 9 input/output bus setup dannymart Pro Tools 9 1 10-24-2011 08:18 AM
delay compensation latency in input only mode vans316 Pro Tools 9 7 11-29-2010 06:29 AM
An 8 Input PTMP Interface That Has ADAT Output? Petander Pro Tools M-Powered (Win) 12 03-29-2006 01:00 PM
