Old 10-09-2017, 08:31 PM
WillowWolf WillowWolf is offline
Default Mute/ unmute MUST Solo
I found a couple of threads with no final answer or solution. I have a project (audio book) that I must keep working on. However all of a sudden I can't unmet previous tracks. I press the M and it goes shadow orange unless I solo the track. What's Going on? Why can't I just unmet the track? How do I fix this? Thanks! :)
Old 10-09-2017, 08:52 PM
Default Re: Mute/ unmute MUST Solo
Sounds like you enabled Mute-Safe? Ctrl-click on the button to toggle safe mode on/off. This works on MUTE, SOLO and RECORD buttons
Old 10-09-2017, 10:14 PM
Hi Dave,
Thanks - yeah - I tried that - nothing happens. Thanks! I will do some investigation on safe modes though! Maybe that will lead to something. More than I had before. THANK YOU!
Bradetta
Old 10-09-2017, 10:59 PM
OK! NOW the mute comes and goes at random. I tried to copy the audio to another track. Same thing. The space bar is not turning on the mute as well. It is just going mute crazy and random. I can't figure out a rhyme or reason. I went to the
Old 10-10-2017, 01:45 AM
ViTheVault ViTheVault is offline
May be you where in latch mode and recorded an automation...
Ctrl+command an click on mute button
You will have the automation track for the mute button... Clear it.. (select and delete)
Then deselect the mute in the automation so it doesn't happen again...
And check your pref....
Good luck
Sent from my SM-G900H using Tapatalk
Send mute/solo follows track mute/solo pre-fader Roger_Jam_Jet Windows 3 09-24-2017 02:59 PM
Speaker mute,unmute, record track mute,unmute for ADR garret Post - Surround - Video 7 09-04-2015 02:03 PM
possible to mute track and unmute another "linked" crizdee Pro Tools TDM Systems (Mac) 5 06-19-2007 07:55 AM
Mute/unmute latency?!? marcelloz Pro Tools TDM Systems (Mac) 2 06-25-2001 03:40 PM
mute/unmute region command changed? mixaudio Pro Tools TDM Systems (Mac) 4 05-26-2001 10:04 AM
