Old 10-02-2004, 07:38 AM
dmanley123 dmanley123 is offline
Default Problems When Using the Digital Input
Hi folks!
I have question that I hope soemone has an answer to. I recently got
a Digidesign mBox with ProTools LE 6.4 and am running it under
Window XP. I have used it for awhile with no problems (using the
analog inputs). Last night I decided to record some sequences from
my Technics WSA-1 and use the syth's digital out instead of the analog ones.
It looked like it was recording OK, and I was showing incoming
signal to the computer, but two things happen. Abruptly in the
middle of a sequence, all the audio drops out (but the sequencer is
still playing). When I try to listen to what has been recorded so
far, all I hear is static. Do I need a "Digital Recording for
Dummies" book or has this ever happened to anyone else when using
digital the digital input on the mBox ?
Old 10-02-2004, 07:52 AM
lemix's Avatar
lemix lemix is offline
Default Re: Problems When Using the Digital Input
dmanley123 ,
Welcome to the DUC...
You'll have to make sure that the PT session is setup with the same sample rate as your Technics WSA-1 puts out (44.1 or 48 Khz)
Then, in your hardware setup> clock should be SPDIF as well.
Should work...
good luck,
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Old 10-02-2004, 04:44 PM
Ah! Changing to 48 KHz solved the problem. Thanks for taking the time to reply.
David
Is there a way to use a digital input at 96k from a digital output at 48k? rockguitarist1255 Pro Tools 10 3 01-04-2012 06:48 PM
Firewire 1814 Digital Input Problems! Akoppenheffer Pro Tools M-Powered (Mac) 2 08-16-2007 11:14 AM
Digital Input on 17" powerbook nightmarefalcon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-13-2005 01:00 PM
Problems with Digital input from DAT to Mbox ddotbach 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-25-2005 11:02 AM
Digital Output from 888/16 isn't compatible with Digital Input of TC M2000 & PCM 80 beerbr Pro Tools TDM Systems (Mac) 0 11-02-2000 09:01 PM
