Old 10-20-2019, 03:47 PM
dg27 dg27 is offline
Default OK to change bit rate for an existing session?
I'm currently always recording in 24 bit/44.1 kHz.
But I have some older projects that were recorded in 16 bit/44.1 kHz.
Is it OK to change those to 24 bit/44.1?
I have additional work to do on these sessions.
I tried searching for this on this forum, but the answers I found all seemed to include the user wanting to change the sample rate as well (which I don't want to do).
Old 10-20-2019, 04:19 PM
Default Re: OK to change bit rate for an existing session?
You are asking about the bit depth, not really the the bit rate (OK the bit rate changes with bit depth art fixed sample rate, but still...). Which may be why you are not finding anything. Folks do this all the time, Save Session In...
There really is no downside (small increase in storage space) all upside in working at higher bit depth.
If sending back to 16 bit later you get to decide when/how things are dithered back at 16 bits.
But why are you working at 24 bit fixed? Why not have all your sessions in 32-bit float?
Old 10-20-2019, 05:34 PM
Thanks for your reply.
OK--then let me rephrase the question: Should I change my existing 16-bit sessions to 32-bit float?
Old 10-20-2019, 07:44 PM
BScout BScout is offline
Yes. It's fine. I often change my 32 bit float sessions to 24 bit right before I need to create temp files to send to a picture editor. And then I change it back after creating files (it's so consolidated files are created as 24bit and not 32 bit float)
Pro Tools Ult 2019.12, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 10-20-2019, 09:09 PM
Thanks.
Old 10-20-2019, 10:15 PM
Yes!
Old 10-21-2019, 09:18 AM
...Folks do this all the time, Save Session In...
No need to "Save Session Copy In..." - you can change bit depth in your session any time you want in the Session Setup Window. Existing audio will remain at previous bit depth but all newly generated audio (via recording, commit, bounce) will be at the new bit depth.
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.12.6, PT 2018 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
Can I change the sample rate of an existing session? (PT9) bicasaur macOS 2 07-28-2013 02:40 PM
Change SR on an existing session? GrievousAngel Pro Tools 9 7 12-30-2011 10:01 PM
How to Change A Session's Sampling Rate homegirl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-17-2007 02:29 AM
Sample rate change during session? JonMitchell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-02-2005 11:47 AM
Changing the sample rate of an existing session Torgo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-12-2004 09:52 PM
