Meter activity but no audio output when monitoring audio input
I am trying to record audio from hardware synths which I then edit in PT. All was working fine up until a few hours ago when the monitoring of incoming audio suddenly stopped. I am now left in the following situation: - playback of recorded/imported audio outputs as normal - recorded and live MIDI plays back and outputs as normal (and triggers notes on the synths) - when I play MIDI in realtime I see audio activity on the meters of the incoming audio track (record enabled + auto input monitoring), HOWEVER, no audio goes to the master track (audio is also coming into the soundcard) - if I record this same track whilst playing back (with the same settings), the audio is recorded but the incoming audio is not sent to the master track - if I then playback what I have recorded (settings remaining the same) then the recorded audio IS output - just to complicate matters; when I play back a recorded MIDI sequence I DO NOT see or hear any audio until after I stop playback, when any decay/reverb shows as audio activity on the meter but again without outputting audio I have had a search but cannot find anything in the help or on this forum which helps so sorry if I am simply missing something, however any help that you can give is much appreciated. Thanks in advance. Chris |
Re: Meter activity but no audio output when monitoring audio input
Sorry I missed my specs from the signature:
MacBook Pro (retina mid 2012), 2.6 GHz core i7, 16GB RAM, OSX 10.8.5, Focusrite Pro 24, Pro Tools 10.3.8 |
Hi christarren,
I would like to assist you but will need more information about your versions of MixControl, connections, etc. Can you please contact us directly so we can assist you better? http://us.focusrite.com/answerbase/contact Best regards.
Katherine Kaplan // Focusrite Technical Support http://www.focusrite.com/answerbase/en/ |
Hi Katherine,
I'm running MixControl v3.3 and the firmware on my Pro24 is v2761. It is connected to the Thunderbolt port on my mac using a firewire 400-->800 cable and then Apple's firewire-->TB adapter. As a note, this problem is only materialising with PT. All other DAWs and other audio software works fine so I can only assume that the issue is somewhere within the PT side. Thanks for your help Chris
Hi Christian,
I am assuming here that you are trying to Monitor incoming audio in Pro Tools rather than Saffire MixControl (Hardware Monitoring). I think maybe you changed your Input Monitoring in Pro Tools from Input Only to Auto Input or vice versa. This is found in Pro Tools Track Menu > Auto Input Monitoring or Input Only Monitoring Selection or Command + K. You can also Monitor Audio in Saffire MixControl rather than in Pro Tools. To do this go to Saffire MixControl and hit File > Restore Factory Defaults, or switch to the Ultra Low Latency or Zero Latency Routing Preset. Please let me know if I can assist you further. Best regards.
Audio Input Monitoring | djcheeze | Pro Tools SE and Essential (Win) | 1 | 01-27-2011 01:39 PM |
No input Level or activity on Meter | spgovert | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 20 | 01-14-2010 05:47 PM |
Audio Monitoring Meter? | Blissfire | Pro Tools TDM Systems (Mac) | 5 | 09-25-2007 06:48 AM |
Audio input monitoring button on C24 | tamtamstudio | ICON & C|24 | 0 | 11-23-2004 06:12 AM |
level meter freeze while monitoring input? | artguilljr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-04-2000 03:52 PM |
