Old 10-30-2011, 08:08 AM
klyg klyg is offline
Default Pt10+Eucon 2.6.2+v-control po : hui problem !
Just report that upgrading to Eucon 2.6.2 and to pt10, v-control pro on iPad2 is not recognized. Pt message errors says problem with hui ???
I also open a tickets Chez NeyRinck. Hope fast solutions.
Old 11-13-2011, 02:57 PM
patlagoon patlagoon is offline
Default Re: Pt10+Eucon 2.6.2+v-control po : hui problem !
I have kind of a similar problem. With PT10 and V-control pro, under set up > peripherals > midi controllers, I can't select HUI, only 'none' appears in the menu. Although v-control is selected in set up> midi>input devices. Any news? Thanks.
Old 11-17-2011, 05:11 PM
dracoso dracoso is offline
same problem. v-control pro works great on pt9, but not stable in pt10, disconnects and makes pro tools and computer freeze. already lost work because could not save session after it freezes.
it used to work great in pro tools 9
any solution or work around?
(pro tools 10 is awesome, but honestly the software is... overpriced!!!!
it should be an update, not upgrade...)
Old 11-18-2011, 04:50 PM
pneyrinck's Avatar
pneyrinck pneyrinck is offline
Neyrinck
When updating to Pro Tools 10 from a previous version, Pro Tools does not remember the enabled MIDI device inputs. You need to re-enable the V-Control MIDI input in the Setup->MIDI->Input Devices dialog.
Old 11-18-2011, 08:26 PM
mattrixx mattrixx is offline
V-Control Pro is working great here with PT10 & 10.7.2
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Eucon 3 - Artist Control not connecting to PT Trazan Artist Series 50 04-04-2016 03:14 AM
Eucon, Artist Control and mouse. vinnyburns Artist Series 6 04-16-2014 06:43 PM
Eucon 3 problems - Mix and Control DrFord Artist Series 5 03-23-2014 08:57 AM
Artist Control not working with Eucon 3 on OS X 10.8.4 Jerry Woolsey Artist Series 1 06-24-2013 01:21 AM
PT10 Eucon and Preview evs Artist Series 1 11-19-2011 05:25 PM
