11 Rack ON/OFF Sound Glitch
Hi There, first post on this site.
My Problem is that when i start 11 Rack, sometimes there is no sound coming out either from speakers or the phone jack, and i have 2 cut the power of and on many times (2 - even 10 times) before it comes back and i can work again. This really pisses me off, especially when i really need it for my work. will be happy for any advice and help. (I have everything updated to the newest firmwares both PT and eleven rack) Respectfully Ion. |
Re: 11 Rack ON/OFF Sound Glitch
Sounds like you have a bad unit. Should contact tech support. They will go over some troubleshooting stuff w you and if it still don't work they will issue you and rma.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
This is a known issue with the 11R:
http://duc.digidesign.com/showthread.php?t=273395 What is really annoying is that about more than two and a half months after Avid has identified the cause for this issue (some defective capacitors) there are still defective units in circulation. Avid claims they cannot track this issue down to a particular batch of units, so in the end it is your/our problem (guitardom can speak from his own experience) ... My 11R exhibited some strange behaviour like adding volume and some nasty distortion while playing with a clean preset dialed. I was lucky I was not playing over my headphones. After nearly two weeks I am still waiting for a response from Avid Tech Support whether this might also be caused by defective capacitors (I don't want to send it back to my dealer on spec and receive a replacement unit that someday will exhibit the same strange behaviour. I do not want my ear-drums being damaged because of defective components in my gear). I would really like to sell my unit, but I am having some qualms about doing so because I certainly don't want anybody else's ear-drums to be toasted ;-) Contact your dealer and ask for a replacement unit. Good luck! |
Mix + Control, Studio One V2 Professionel |
Moin, moin, fsb1,
schöne Grüße von der Waterkant Hast Du dein Gerätchen bei justmusic gekauft? Yep, great work or great quality management ... But on the other hand: If they want to offer the 11R at a competitive price they have to use cheap bulk freight ... |
i checked the other threads and tried the reset memory thing it worked but i'm skeptic, if it is a hardware problem (defective capacitors) no idea what that is but the problem will still be there right?, so maybe replace it with a new one. Thanks // Jon |
I guess you can assume that this is a hardware issue (capacitors or other components, Avid keeps shtum about that). If you are having a hardware issue you can expect it to occur again. I had three issues with the 11R in 5 days:
- treblish sound without any bass and mids - no sound at all - adding volume and nasty distortion while having dialed in to a clean preset I have gone rid of the first two issues by doing a memory resets, and the third issue was gone after a restart. I do not know whether any of these issues occured again because after the last issue occured I did not play over the 11R any more. I am not interested in getting to know other issues the 11R has up it's sleeve for me ... |
i have purchased 3 units, and all 3 of them had to be returned and repaired to make a long story short....
thanks for all information and help. Thanks // Jon |
Thank you // jon |
11 Rack ON/OFF Sound Glitch 2 | ontheroad | Eleven Rack | 2 | 11-27-2010 01:35 AM |
Sound glitch(?) in PT8 | CamM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-29-2009 01:37 PM |
iTunes sound glitch through Digi 002 | Paul Alvarez | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-15-2006 09:12 PM |
30 second glitch with Logic and 002 Rack...??? | Muzoid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-27-2004 06:11 AM |
Punch in Clicking Glitch sound | rrhodes1 | Pro Tools TDM Systems (Mac) | 5 | 09-04-2003 11:45 AM |
