Old 08-07-2013, 07:00 AM
murks murks is offline
Default Mix Stem 1/2 fr to early
Hi there
I am mixing an short film in the box,
all in one computer - no extra stem rec PT.
If i take a brief look at the sync check beep - i can see that its is on the Mix Stem almost half a frame to early - on the audio track which delivers the beep it is in sync.
So only on the rec stem everything is half a frame to early.
If i turn on / off delay comp - nothing changes...
Anybody has an idea?
Thanks a lot
cheers
Martin
Old 08-07-2013, 10:14 AM
joachim's Avatar
joachim joachim is offline
Default Re: Mix Stem 1/2 fr to early
The letters "Dly" in the counter under "Start/End/Length", is that written in green or red ?
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 08-08-2013, 12:13 AM
Hi Joachim,
Dly comp is green ....
Thanks
cheers
Martin
Old 08-08-2013, 11:40 AM
joachim's Avatar
In the mix window, delay compensation displayed, under the track name,
is there any minus value in the field "+/-" ?
Old 08-08-2013, 08:06 PM
kd_special kd_special is offline
I have had that before. But that was TDM systems.
And usually because of bussing power. I had so much of it going on. specifically when i had a track that held my 2beep and tones. and then it was bussed to all my record stem tracks.
dont know if that helps at all
kd
Old 08-10-2013, 07:27 AM
everything helps !
thanks a lot
cheers
martin
HTML code is On
5.1 stem Rune Thuelund Post - Surround - Video 1 12-22-2011 02:30 AM
Help Creating STEM please. LSJ Pro Tools TDM Systems (Mac) 7 02-10-2011 06:47 PM
Stem reverb garimpo Post - Surround - Video 2 05-04-2009 09:28 AM
Stem Mixing on LE? rickf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-08-2007 01:56 PM
Add Stem question soundezign Post - Surround - Video 1 08-10-2006 05:02 AM
