Old 06-09-2002, 04:19 PM
Joseph Anderson Joseph Anderson is offline
Default help! I created a session that\'s too big to open
Okay, I got a little carried away with the RTAS plugs, and I created a huge session. But now it won't open at all! I increased the buffer size in DAE to the biggest, but every time I try to open the session, it hangs the computer.
Its weird because I created the session from scratch on this computer. Its hard for me to understand how the session can't even open, since it was created here. But so you know, I shut down and cleared the memory (cold boot) before trying to open the session and -- no joy.
Any ideas? At this point all I'm trying to do is use audiosuite to get rid of some RTAS plugs, delete tracks, etc., so this thing will run?
All thoughts appreciated!
jla
Old 06-09-2002, 04:22 PM
Drew Mazurek's Avatar
Default Re: help! I created a session that\'s too big to open
Make a new session and import tracks from your stuck session and do some of the audiosuite stuff until you clear the bottleneck.
drew
www.drewmazurek.com
Old 06-09-2002, 04:25 PM
Awesome suggestion. Why didn't I think of that? Thanks a lot, man.
jla
Old 06-09-2002, 04:28 PM
Come to think of it, though, how will I know my precise audiosuite settings, since I won't be able to look at the RTAS plugs in the old session? Is there any way to unstick the stuck session?
jla
Old 06-09-2002, 05:19 PM
TooLoud TooLoud is offline
Not sure if your trouble is the same as what I had, but I ran out of room doing a live session 3-4 months back and tried to squeeze a little more out of the session after it had shut down, and it shut back down after about 10 seconds. When I tried to open the session again later, it wouldn't let me 'cuz I had used up the little buffer that is left in the session for file info etc. Thought I was dead in the water, but after moving some files onto another drive it opened with the "where is audio file xx?" query, so I was able to "save the session as" to another drive and reassemble the session. Whew! Went out and got bigger drives after that...
Doug
"But then again, what do I know?"...
Harbour Sounds
Old 06-09-2002, 05:37 PM
axmen axmen is offline
Don't know the answer but, I wonder if adding RAM would help functions such as opening big sessions?
Old 06-09-2002, 06:09 PM
SAMP SAMP is offline
Did you try allocating more memory to Pro Tools? Click on the app once, hit command I, go to memory under the "show' window and increase the RAM allocation. This works with photoshop and strata. Just a suggestion.
http://www.rullian.net
Old 06-09-2002, 06:14 PM
Frank S Frank S is offline
<font size="2" face="Verdana, Arial">Remove the most CPU hungry plug-ins from the DAE plugins folder, trash your DAE preferences and restart. This way when PTLE launches, it will give you a dialog box saying that so and so plugin isn't available, but you should be able to open your session. Remove those greyed out plugins from the Mix window channels, and then 'save session as' and quit PTLE. Now you can put the plugins back into the DAE folder, trash DAE prefs and restart PTLE again. Voila, you can open your session - the new one you created, not the original bloated one. I'd get rid of Realverb, Sansamp, anything else Bombfactory, Autotune, Waveshell 3.2 - if you have any of these on your session. If not, even getting rid of Dverb could help make enough room to open the session. You probably only need to remove ONE of the most CPU hungry ones on the track, and you can leave it on your desktop while you're fiddling.
Frank S
[email protected]
Old 06-09-2002, 06:44 PM
accession accession is offline
Great tip, Frank!
Phil [img]images/icons/cool.gif[/img]
Old 06-10-2002, 02:03 AM
Bunting Ho Bunting Ho is offline
Frank S, TooLoud and Dmazurek, any of those suggestions sound like they would solve the problem. This is one page I shall print and stick in my DUC folder. Well done!! [img]images/icons/tongue.gif[/img]
J
Can not open last session !It says it was created with older version of PT !?! WTF ?! mrpollack Pro Tools 10 2 12-19-2011 10:45 AM
Can't open session it's created with an older version of PT James Drake Pro Tools TDM Systems (Mac) 6 08-22-2011 08:17 AM
Session created in PT HD 8.1 will not open in PT M-Powered 8.0.4 ianvargo Pro Tools M-Powered (Mac) 0 10-26-2010 03:57 PM
Session won't open. Says it was created by older violetsun 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-28-2008 07:52 PM
open mbox created session on my 002 Jeff Harris 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-22-2004 03:05 PM
