Routing Mac sound into Pro Tools
Is there some sort of a ReWire-style plug that can capture Mac's audio before it is routed to my sound card? Cheers.
2023.12 Ultimate / Mac Pro (Late 2013) / 6 core 3.5GHz / 64Gb / OSX 12.7.2 / MTRX Studio / 2xArtist Mix / PT|Control / Aja T-Tap |
Maybe you should explain exactly what you are trying to accomplish, and in what way, with a little more detail
Re: Routing Mac sound into Pro Tools
Yep... why “rewrite like”? What *exactly* are you trying to do?
Popular CoreAudio routing tools: soundflower, loopback, jack, ... Popular plugin rewire hosts: Vienna Ensemble Pro (presumably not what you are after) |
OK, I'll try to explain:
Both Pro Tools and Mac audio are routed to my sound card (Mbox). Is there a way I could listen and record the sound of my Mac (browser, system sounds, skype etc) via Pro Tools. Not with physical wiring from Mac nternal audio out.
Thank you so much
Source Elements - Source-Nexus makes it in a plug in format...
ihatetyping |
Audio Hijack is a great tool for recording application/system audio.
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • Dock • Mac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W |
Thanks elicious, Trent
I've used Soundflower but to be honest the sync can be a pain so I generally just use the mini jack out from the Mac into my audio interface.
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2 https://www.waves.com/r/djgsi6 |
Output routing settings for speakers without sound card | Kurout | Pro Tools 12 | 4 | 12-21-2017 10:39 AM |
Kontakt 5 AAX Pro Tools 11 HDX Routing | fretfingers | Pro Tools HDX & HD Native Systems (Mac) | 22 | 03-20-2014 12:25 PM |
routing OSX sound (iTunes) to PT9 | Fritz | macOS | 6 | 07-14-2013 05:38 PM |
routing to amp without pro tools | apartmentstudios | Eleven Rack | 2 | 04-21-2013 04:49 PM |
Routing all sound thru MBox-2???? | RemStarr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-06-2006 11:44 AM |
