Digital I/O discovery/question
Hey all - I just wanted to pass something along and also get some feedback from some of the more technically gifted members. I'm running PTHD w/ a 192 I/O. I've grown very attached to the programs I've written in my 2 Lexicon PCM80's. Just as a goof I tried running the outputs of the PCM80's(set for internal clock 48k) Digitally into the AES inputs of the 192 running at 96k - and - VOILA! it works! I use SPDIF to AES converters I built on the outputs of the PCM80's. The 192 must do the conversion math easily 'cause it's just 48k x 2. It seems to sound fine. Pretty good actually. Way Way quieter than using them analog. The Lexicon D/A's are pretty noisy so this is a godsend solution.
Question is, is there going to be junk or artifacts in the signal? Is there any reason I shouldn't do this? As opposed to using expensive sample rate converters. Thanks - Eric |
Re: Digital I/O discovery/question
If it sounds good to you than it is good. |
USB Discovery | Fezzler | Eleven Rack | 2 | 09-13-2012 07:10 AM |
Newbie Digital IO question - HD Digital i/o vs 192 Digital vs X-HD | mrdosun | Pro Tools 10 | 1 | 02-16-2012 11:20 PM |
Discovery M+E question (help making tapes today) | feakerboo | Post - Surround - Video | 1 | 01-10-2006 02:21 PM |
i have made a discovery | alienzombe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-23-2002 04:59 PM |
001/Digital Timepiece/ADAT Synchronization Discovery | InjuredEar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-01-2001 06:50 AM |
