  #81
Old 03-24-2018, 05:47 PM
mitekillem's Avatar
mitekillem mitekillem is offline
Default Re: 12.8.2 - access violation errors
I recently encountered this issue when I had to downgrade from 2018 to 12.8.3 as PT no longer supports Windows 7.
The weird thing is it only seems to affect clips/regions both midi and audio.
-Not anything in the audio pathway, playback, inputs, hardware controllers, etc, etc; Just the clip locations and editing points. As soon as you try to move anything dealing with the clip, it will throw up that error.
The file that deals with clip data in PT is WaveCache.wfm. So I figured, let's try to delete it as PT will recreate it when it opens the project.
I deleted my project's WaveCache.wfm, and re-opened the misbehaving project, and so far it's working with zero problems. *fingers crossed*
I'm uncertain if this is a workaround or if the project just started behaving on it's own, as I haven't had more time to test. But hopefully this will do the trick.
  #82
Old 04-09-2018, 05:42 AM
leomartins leomartins is offline
Someone knows if this problem is solved in Pro Tools 18?? Thanks!
  #83
Old 04-09-2018, 08:06 AM
seanmccoy seanmccoy is offline
I haven't seen it once since the move to 2018.
ADK Core i7 4.20, 32GB RAM, W10 Pro, PT HD 2019.6, HD Native, OMNI, Digi 192, AJA Kona LHi, UAD-2 Quad; Mac Pro 8-core 2.67, 32GB RAM, High Sierra 10.13, Logic Pro 10.4.6, Apogee Rosetta 800, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Sierra, MOTU LP32, Pro Tools 2018.3
  #84
Old 04-10-2018, 04:14 AM
Thanks!
Access Violation errors DonaldM Tips & Tricks 0 05-31-2011 05:07 AM
Help with 'access violation' errors on an i7 please. jonnn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-12-2009 12:00 AM
Access Violation Errors latprod Pro Tools M-Powered (Win) 8 02-25-2009 06:07 AM
Errors in GDI.EXE & Access Violation 2Sick_Music 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 02-11-2003 05:41 PM
