Old 05-17-2011, 04:56 AM
jimdpie jimdpie is offline
Default The 8.0.5 update has broken my computer
I've just run the PT LE 8.0.5 update and my computer now hangs on "loading operating system" (which is Windows7).
Any suggestions? Version 8 was previously working ok.
Old 05-17-2011, 07:57 AM
sunburst79 sunburst79 is offline
Default Re: The 8.0.5 update has broken my computer
Try launching Windows in SAFE MODE and then reboot. This doesn't seem to be a common issue so I'm guessing its unique to your system.
f that doesn't fix it I would boot into Safe Mode and un install the 8.0.5 update and see if that makes a difference. I would update your PACE drivers if they are not the latest version and try the update again.
Also you may want to disable DEP if you haven't already. Just a hunch.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 05-17-2011, 09:01 AM
Ok, thanks.
Can somebody explain why the PACE drivers might be an issue?
Old 05-17-2011, 09:10 AM
fredrickj fredrickj is offline
i have same issue. Mbox 2 mini and latest drivers works fine with Ableton DAw. Id rather work with pro tools but loading it causes numerous BSOD,s. This is true with several different mobo's and processors. Haven't found a solution yet but to not use pro tools. Sucks....
Old 05-17-2011, 10:26 AM
JMS40 JMS40 is offline
Originally Posted by jimdpie View Post
Ok, thanks.
In LE software, the PACE drivers control authorization.
Old 05-17-2011, 10:54 AM
But why would they prevent the system from booting?
Old 05-17-2011, 11:14 AM
Pinball Wizard Pinball Wizard is offline
Default
I also have not been able to use .5. I had to uninstall & go back to .4. I had Windows Explorer problems. I must admit that I didn't try to work things out, I just gave up & all has been fine for me ever since.
Main Workstation: Pro Tools 2023.12.1, Windows 11, HP Z4 Xeon 8 core W2145, 64 GB DDR4, Omni, Artist Mix, Sync X, Eleven R(2 of them), UAD 2 PCIe card
Pro Tools 'broken' after 10.1.2 update Veranova Windows 8 04-18-2012 09:59 AM
Core Audio Manager for 002 broken after 10.1.2 update? EricJ 626 macOS 2 04-12-2012 11:51 AM
'Your Computer is missing a Windows XP update Colin_09 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-22-2009 01:36 PM
25 ghosts computer must be broken!! crizdee Pro Tools TDM Systems (Mac) 2 04-23-2008 01:21 PM
Help! 6.1.2 update killed my computer! jes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 10-14-2003 11:16 PM
