Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 02-09-2018, 01:37 PM
Mahzinho Mahzinho is offline
Default Hybrid Mixing Question
Hi people, how are you? My name is Marcos and my question is the following:
Nowadays I mix ITB and want to buy for the future a mixer for do hybrid mixing. I was analyzing and as the sound is leaving from Pro Tools, going to the mixer and returned to Pro Tools, the correct is: 1,2,3,4,5,6,7,8 (Outputs from the interface) to 1,2,3,4,5,6,7,8 (Inputs/Line Inputs from the mixer) and 1,2 (Outputs from the mixer) to 1,2 (1-2 inputs from the interface). If I do this and in Pro Tools do the same: ch 1 (output = not the main output of the interface, but output 1-2 linked to input 1-2 from the mixer), ch 2..., and all recording to one audio track with input 1-2 and output as normal output of the interface, it's correct? Do you think that one Soundcraft mixer or Behringer mixer with an 8-output interface/input will be great?
Old 02-09-2018, 02:25 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Default Re: Hybrid Mixing Question
Just my opinion but I think the only good reason to come out of your DAW would be to go through a high dollar console. Maybe you've read about hybrid mixing and think you can improve your mixes but the fact is the sound quality of an inexpensive mixer such as you are talking about would not improve and could potentially harm the sound of your mixes. The people you hear of using hybrid mixing do it because they want the sound of say an SSL, Neve, or Amek channel input, eq, comp , etc , I suspect, usually to have the transformers coloration. Some consoles can also be used as a control for Pro Tools but if you aren't actually using a mixer for it's "sound", you would be better served by picking up an Avid/Pro Tools mixing surface. And if you're looking for the sound , then you will be better served by picking up channel strips/modules. Only my opinion!
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 02-09-2018, 03:17 PM
Well, where I live (BR) all is expensive and I would try with a mixer of R$1.400,00 - R$2.000,00 ($29 is almost R$100,00). Well, I like analog, but I want something that won't consume so much in watts.
Old 02-09-2018, 07:50 PM
amagras amagras is offline
I would go with Waves NLS, it sounds as good and I can't stand the idea of depending of external hardware to recall my work anymore. It's also only $100R when on sale.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 02-16-2018, 09:23 AM
My vote as well(or maybe Slate VCC). Going thru a high-end console, or a high-end analog summing box CAN impart some good qualities onto a mix. However, (and this is the great big "BUT") a cheap console(which is what you are talking about) is not likely to make anything sound better, and will complicate your workflow in a big way(probably in many ways that you haven't thought of). Many of the busiest and most famous(highest paid) mixers are now working completely in the box, so I suggest you hone the craft of mixing(experience is the best teacher) and worry less about the hardware
This is very similar to the question we see a lot where someone is just dying to insert some DBX or alesis compressor, or thinks they can do a better mix if they could only use that old Lexicon Alex unit.... The single most important piece of "hardware" is the person holding the mouse
Quick Key idea for hybrid atmos mixing ryandcole Tips & Tricks 20 11-17-2014 01:58 PM
Hybrid Question gtomassetti macOS 6 04-22-2013 08:35 PM
Hybrid question Dopamine Virtual Instruments 3 07-16-2010 10:16 AM
Hybrid question StinkyStan Virtual Instruments 10 08-02-2009 06:26 PM
Hybrid question DonaldM Virtual Instruments 5 05-12-2008 06:16 AM
