MBox Pro Driver Hardware Found
I have an MBox 2 Pro
I have a dual boot system. Partition one is Pro Tools with optimized Windows. Partition 2 is my cluttered Windows XP Media Center SP3. How do I make the "found new hardware" dialog box not put up everytime I load my cluttered windows partion? Is there an ASIO driver I can load on my non-Pro-Tools partion so the MBox Pro is recognized? If I knew what driver to install, I could even use the MBox Pro as my windows sound card in my non-Pro-Tools partion. What is the link to the current stand alone MBox Pro driver?
MBox 2 Pro connected to motherboard 4 pin firewire port Dell Inspiron 9300 laptop 2.0 gHz Pentium M 2 gB ram Lacie Rugged 5400 rpm firewire 800 on Siig Cardbus adapter Roland 700SX stage piano Studio Projects C3 mics Melodyne Plugin Dual Boot: PTLE 8.0.1 on Windows 7 Enterprise 32 bit PTLE 8.0.1 on XP Media Center SP3 |
Re: MBox Pro Driver Hardware Found
This should be what you are looking for.
Keep in mind a few things;
Thank you. That is what I was looking for.
You could also install Pro Tools and just not use it. I had a PC running MCE 2005 and PTLE for years. It's where I would test new plugs etc.
MCE is not approved...It's not like installing PT will cause heavenly bodies to collide or your interface to catch fire. Usually
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
That stand alone driver did not work. My MBox Pro has a yellow exclamation mark next to the hardware in the device manager even though I installed that driver. hmm. What do I do now?
Uninstall the standalone driver and install Pro Tools.
I found my problem. I had the Unibrain 5.21 ubCoreFlat driver for my firewire port and card. This is incompatible with my system. I uninstalled that driver and let the Microsoft default firewire driver control the firewire ports and then it was easy to get the Digidesign hardware to be recognized by the Digidesign hardware driver.
Hardware not found? need help mbox mini 3 | egarcia530 | Pro Tools Express on Windows | 1 | 06-04-2013 03:01 PM |
New 10.0.1 driver update for mbox 2 not found. | onepercentfree | Pro Tools 10 | 0 | 01-28-2012 07:32 PM |
mbox 2 hardware mini not found - please help | andia56 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-03-2009 08:50 AM |
MBOX- ALL LIGHTS ON-- HARDWARE NOT FOUND | rgeorge | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-20-2005 07:13 PM |
Mbox: Hardware not found | pmichael | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-24-2005 01:56 PM |
