How to use different timbre(articulation)in 1 track ?
For instance,i load 2 timbre (legato and pizz.),and i want to use it in 1 track with flexible switching instead of creating 2 instrument tracks(one for legato,one for pizz.) ,which is similar to the "exp" in Cubase and the "articulation" in logic.
How to do that in protools12?pls |
Re: How to use different timbre(articulation)in 1 track ?
Hi, welcome to the community.
Please download the Pro Tools Reference Guide pdf and search for automation.
This may or not be helpful https://divisimate.com/
PT 2022.12 studio, Cubase 12 Pro, 12 Core Mac Pro 6,1 96GB OS X 12.6.6, Mac Mini i7 QC 16GB, Digico Soundgrid DLI, Revive Audio 96IO & 192 DBox & 2BussLT for summing, Waves, SoundToys and a pile of other plugins. NI Maschine/Komplete Ultimate 12 and many many, too many Kontakt Libraries. https://www.youtube.com/channel/UCmT..._as=subscriber Last edited by LoudBassTone; 01-18-2023 at 07:05 AM. Reason: edit |
Got it,Thank you so much
Thank you
Also in reading the reference material, negative track delay when the sample starts, is the only way to get the tracks to be on the grid with a click track. You need this.
https://www.youtube.com/watch?v=Cd8KOOm_Ktk Update: Pete says: You can use "Real Time Properties" to delay or advance the midi info. You can choose ticks or milliseconds. That can be set to keep the midi editor to display the notes as you played them or where they get moved to. That can be switched on or off. You can also bake it into the track if you like or just a section of the track. You can also use Midi Track Offsets to move the entire track around...
PT 2022.12 studio, Cubase 12 Pro, 12 Core Mac Pro 6,1 96GB OS X 12.6.6, Mac Mini i7 QC 16GB, Digico Soundgrid DLI, Revive Audio 96IO & 192 DBox & 2BussLT for summing, Waves, SoundToys and a pile of other plugins. NI Maschine/Komplete Ultimate 12 and many many, too many Kontakt Libraries. https://www.youtube.com/channel/UCmT..._as=subscriber Last edited by LoudBassTone; 01-23-2023 at 05:47 AM. |
It also depends on what (presumably) sample library you're using. Different devs have different methods for articulation switching if you can load multiple in one instrument. Sometimes it's MIDI notes (outside of the instrument range). Sometimes you can do it with Program Changes, which you can insert into a CC lane on the Instrument/MIDI track. Learn the instrument and you'll be a step closer.
Kerry Smith http://apothekerry.com Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro |
PT 2022.12 studio, Cubase 12 Pro, 12 Core Mac Pro 6,1 96GB OS X 12.6.6, Mac Mini i7 QC 16GB, Digico Soundgrid DLI, Revive Audio 96IO & 192 DBox & 2BussLT for summing, Waves, SoundToys and a pile of other plugins. NI Maschine/Komplete Ultimate 12 and many many, too many Kontakt Libraries. https://www.youtube.com/channel/UCmT..._as=subscriber |
This was an interesting video some posted on facebook. back half when Andy from Avid shows his workflow. https://m.youtube.com/watch?fbclid=I...ature=youtu.be
But I either use single tracks in Pro Tools or Cubase because Expression maps after you create them is a built in feature.
Sibeliusの日本語サポートについて(技術的なご質問) | Avid Audio Japan Admin | Sibelius & Scorch フォーラム | 0 | 07-06-2016 11:20 PM |
Pro Tools 11 以降でショートカットが動作しない問題(Mac) | Avid Audio Japan Admin | Pro Tools (Non-HD, LE, M-Powered, Express) フォーラム | 0 | 06-16-2016 04:08 AM |
Pro Tools 11 以降でショートカットが動作しない問題(Mac) | Avid Audio Japan Admin | Pro Tools HD, HD Native、ICONフォーラム | 0 | 06-16-2016 04:08 AM |
TC electronic VSS3が発振(内部ループ)する | soundista | Pro Tools HD, HD Native、ICONフォーラム | 0 | 08-04-2011 05:10 AM |
互換性注意情報: Mac OS X Lion 対応状況(Pro Tools MP 9は未対応) | Avid Audio Japan CS | Pro Tools (Non-HD, LE, M-Powered, Express) フォーラム | 0 | 07-20-2011 06:42 PM |
