Old 10-18-2017, 01:56 PM
Tristos Tristos is offline
Default Correct way to ID hardware insert delay?
Hi All,
Newbie here - been reading for the last few weeks as I transition to PT as my primary daw
I have been researching loads and just need some clarity on sorting out my hardware insert delay MS figure. Im running two Antelope Orion's linked via MADI using an RME Madiface.
Im a logic user and it seemed so easy with ping etc, but need to configure PT 12 correctly. Im using PT 12.9
Thanks
Old 10-18-2017, 03:21 PM
john1192 john1192 is offline
Default Re: Correct way to ID hardware insert delay?
Originally Posted by Tristos View Post
Hi All,
Thanks
hi, first thing, welcome to the DUC .. next you are not using PT12.9 - because the latest version is 12.8.2
so what version of PT are you using please ??
are you on a PC or Mac .. ??
what operating system .. see where i am going .. ?? more info please ..
yes, logic ping is great, Avid will not put a Ping feature into PT non-HD right now, maybe one day if we keep pestering them
try this ..
https://www.youtube.com/watch?v=Lb5IkX5ADkc
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 10-19-2017, 04:08 AM
Hi John
Thanks for responding apologies 12.8.2
Im running a Mac Pro with 10.12.6
Thanks for the video link, will check it
Tristan
Old 10-19-2017, 08:03 AM
Hi John
Tristan
your welcome, and remember that with each sample rate and each update of pro tools you will need to re-calculate your delay
cheers john
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 10-19-2017, 09:17 AM
DJ Hellfire DJ Hellfire is offline
I have to re-enter and recalculate mine every time I launch pro tools. It never keeps my setting. And some times the delay is different even under the same sample rate. Mine is always either 507 samples/11.5ms or 1024 samples/23.22ms both at 44k. I don't know what causes it to be different some times but it is always one of these two figures. And I am still on 12.7. Have not updated to anything new yet.
www.HellfireBeats.com
UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61
Pro Tools 2021.12
Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2
16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15
Old 10-19-2017, 09:50 AM
damn, thats painful, mine at least stays the same ..
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 10-20-2017, 02:32 AM
Hi Guys
Thanks for the help so far, I think I'm nearly there but I'm trying to follow the routing for the testing on that youtube video and I think I'm getting it wrong, routing send wise as i only get the signal flowing in when input monitoring enabled 'I'
i have ran the tests and i have to nudge the wet (hardware inert) track forward by 208 samples, so using the formula 208 / 44100 x 1000 = 4.71ms
Could you do me a favour and just describe the exact routing i should setup in PT just so I'm sure I'm doing it right as per the video as I'm sure its not right
Thanks T
Old 10-20-2017, 07:07 AM
Hi Guys
Thanks T
pages 1043, 1050, 1076 of the pro tools reference manual ..
note: Hardware Insert - out and back in the same # .. ie: out #3 and back in #3 .. you cannot have different out's and in's !! Logic Can but not Pro Tools ..
other than this what exactly do you think is not right ??
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Why does hardware insert delay change? DJ Hellfire Pro Tools 12 2 08-07-2017 10:17 AM
Hardware Insert Adds Delay dave911 Windows 7 05-23-2013 04:36 PM
need help determine hardware insert delay musicmixer04 Pro Tools 10 1 02-18-2012 10:22 AM
Hardware Insert Delay value for 888/24??? cronos Pro Tools TDM Systems (Mac) 3 01-29-2010 06:50 PM
Hardware insert delay question musicmixer04 Pro Tools TDM Systems (Mac) 1 01-31-2009 07:33 AM
