How to make a double-time click?
Does anyone have an easy way to generate an eighth note click without changing the metering? I'm not dealing with a steady tempo and meter but lots of changes, as comes with film music. Obviously, I need it to follow the already complex tempo/meter map.
Any help is appreciated. |
Re: How to make a double-time click?
use a delay plugin and it'll follow the map. automate it when you need to change notes.
That's clever. Thanks, dmazurek.
On a simple session, I could change the designation of each tempo change to a different note value, but that's impossible on some of these hairy ones. I'll try it. |
chose the note value in the pop up menu in transport. chose a 1/8 instead of a 1/4. thats the real way to do it.
delay will work in most cases but it also depends on how extreme the time changes are. The delay that follow will always be at the tempo it came from previous so it may sem like the like rushes or drags sometimes. Id hace something like Reason follow via rewire with a simple click you come up with. Since it is midi based it will follow tempo changes correctly
HF |
Go to MIDI > change meter, there's a 'click' setting: you can choose values between whole notes and sixteenths. Oddly, I can get accents only on downbeats, if somebody knows how to accent every quarter note, chime in.
R. |
All great responses. I don't think the Transport trick works for me because I'm using the conductor at all times. I noticed that the Change Tempo window does have a "click" note-value menu but that also seems to affect the overall bar counts as well. Gotta RTFM I suppose.
Note: in the Change Tempo window you select the resolution (and it affects the bar count); but it's in the Change Meter window where you can change the Click value, and that doesn't affect the bar count.
R. |
double time or halfe time some midi in PT???? | metaltim | MIDI | 10 | 05-21-2013 03:10 PM |
How to Double Time (or Time Stretch) Midi? | noharmlessrock | MIDI | 4 | 04-02-2008 07:32 PM |
Click - Changing Sub-Divisions - Double TIme | John Pisciotta | Pro Tools TDM Systems (Mac) | 2 | 03-06-2008 12:58 PM |
DAE crashes when I double click it... | hkpwnetd | Pro Tools TDM Systems (Mac) | 8 | 01-11-2001 06:02 PM |
Double click on zoomer? | Przemek | Pro Tools TDM Systems (Mac) | 0 | 12-06-1999 02:13 PM |
