Monitor clipping with no signal input.
I'm new to pro tools. I'm sorry in advance. Ive searched youtube and posts to find a solution for my problem and i've got nowhere for 3 days.
As you can see from the pics below, even without a signal being sent to the input, the output from pro tools DAW is clipping. If I just use the scarlett software without having pro-tools open, i can get it to work fine as far as hearing my guitar through the monitor within the scarlett. When I try to open it in pro-tools, i immediately get the noise as soon as i activate a input channel on my new track. I've tried erasing all the I/O in protools and starting over. that didn't work. I reset to default, that didn't work. HELP!! I've attached pics of my I/O settings hoping it is a simple fix that someone with experience can show me. I am running this on a Dell inspiron13, I76500 2.5ghz, 8gb ram, windows 10 64bit. I just re-downloaded the software yesterday, and ran updates just in case. my scarlett was also just downloaded and updated yesterday (I deleted everything and tried to start over). the settings on my computer audio are all set to the scarlett for recording and playback. https://drive.google.com/file/d/1nAi...ivRx6932JNGmcZ https://drive.google.com/file/d/18Mz...RRMrmdctoH4tOu https://drive.google.com/open?id=13J...rQ2IjFs9gFKPjo https://drive.google.com/open?id=1r4...ACbaxwj6WPz-pV Last edited by rbedwards3; 05-14-2018 at 04:23 PM. Reason: pics arent working |
Re: Monitor clipping with no signal input.
I only see signal in the page titled scarlett mix control , not in the pro tools window. I don't think you need to use mix control with pro tools , usually with focusrite you just use their ASIO driver to run pro tools through.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro PT 2023.3 Studio through an A&H Qu-32 |
Someone said it looked like a feedback loop, which is exactly what it sounds like and looks like. I think maybe in my scarlet control I have something routed incorrectly.
Your ProTools settings look fine. As said above, don't try to use Scarlett mix control when you are using ProTools.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit. |
Cannot monitor input signal | wblackmon | Pro Tools 12 | 7 | 11-04-2021 07:08 AM |
Condensor mic clipping with Input Signal at zero!! | ewan.mcghee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-05-2010 07:49 AM |
Fast Track Pro Outputting Mic input to Monitor, but Pro Tools 8 shows no mic signal | changa86 | Pro Tools M-Powered (Mac) | 3 | 12-18-2009 10:06 PM |
i want to monitor the input signal w/plugs during playback, but not record it... | Joseph Grimm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-05-2003 04:20 PM |
Hot Signal Clipping? | AnalogTree | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-04-2000 07:34 PM |
