#131
Re: Sample Rounding Issue!!!!
Yes they come from different ways
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11 Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7 |
#132
Today was a nightmare. Midi clips that lost notes when copied and changed name. Don' t understand how can orher users live with that. Terrible bug.
#133
I tried to live with it and work around. But after years of Avid sticking its head in the sand, I switched to Logic for composition and largest part of production.
So that's how others do it! |
#134
Yes I agree that using another daw for midi programming is the way to go. But switching back and forth between two daw is very boring. Tried to use logic for the entire production but the mixing process on pt is far better
#135
Switching between DAWs is a real pain for me as times I want to make changes to the production & I have go back and forth between them.....not ideal or creative friendly at all. I'm very close to switching to Studio One completely because of this.
iMac 27" Late 2013 3.5Ghz i7 32GB Ram 3TB HDD, 1TB SSD Samsung 850 Pro, Movaje 10.14.6, Pro tools 2021.7, 2021.3 & 2020.12 installed. UAD Apollo 8 Quad & Satellite Quad, Reason 10.4.1 & Reason Suite 11.3.9, Logic Pro X 10.5.1 (need to upgrade to Catalina for LPX10.6), plugins & VI's by practically everyone. G-Tech Mini 1TB HDD, 3 x 1TB Glyph GT050Q, Lacie Rugged 500GB & several assorted drives.....lots & lots of hardware synths & outboard https://soundcloud.com/2b3productions |
#136
Tried studio one some years ago but didn't find it enough "pro" especially at the mixing stage. Some months ago had the opportunity to buy cubase pro 10 via a crossgrade for only 155 euros. I have to find time for learning it. Had cubase sx3 in the past but now is seems different.
#137
#138
Just an idea some may have already thought of as a workaround for the copy and paste/altered notes issue:
Select the clip you want to copy so that it is highlighted in the clip list. Then drag & drop from the clip list to the desired location instead of copy and paste. Haven't tried it yet but will give it a try my next session. Also, the issues only seem to happen with MIDI clips I create myself and not 3rd party MIDI clips. For example, I can Ctrl + D drum patterns across the board accurately when dropping patterns from my Steven Slate & Toontrack libraries. But if I create a note for note accurate bass line or piano part and copy those; it inevitably gets shifted out of time. Last edited by take77; 02-20-2020 at 09:55 PM. |
#139
Btw there is something broken in the midi engine in PT.
#140
I will take a look
Sample Rounding | budda963 | Pro Tools 11 | 1 | 07-08-2013 06:07 AM |
sample rounding error in pro tools 10??? | DarkDayz | Pro Tools 10 | 6 | 11-02-2011 03:22 AM |
PT and Sample Rounding WILL cause Issues when Copying | 25ghosts | Pro Tools TDM Systems (Mac) | 7 | 07-01-2011 02:25 AM |
Sample rounding issues | bigdoghat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-13-2007 08:20 AM |
Sample rounding, ticks, etc | voce | Pro Tools TDM Systems (Mac) | 1 | 08-03-2005 05:26 AM |
