# of Voices vs # DSP
Under the PlayBack Engine Menu, I have an option to select:
32 voices using either 1 or 2 DSP's 48 voices using either 1 or 3 DSP's 96 voices using either 2 or 3 DSP's. Why would someone choose to use more DSP's just to acquire the same amount of voices? Is there any advantage to using more "precious" DSP's?? |
Re: # of Voices vs # DSP
Okay, So I'll rephrase the question.
If my session uses between 42-48 voices (no more and no less), which # of DSP's would be wise to use: 1 DSP or 3 DSPs? Again, if 1 DSP works without any problems, then why is there an option to select an additional 2 DSP's?? |
When I went from PT 5.3 to 6.0.1 I had some sessions that were giving me PCI bus errors. When I increased the number of chips (for the same number of voices), the problem went away. I believe that using more chips means that PT doesn't have to work the computer as hard.
Jim |
yes, I agree with the last post. I think, it will simply alleviate computer load and pci bus loading issues. I use a magma expansion chasis and I have been advised to raise the number of DSPs to increase reliability, etc.
Doug |
ran out of voices, what is this? | srsoundlab | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-29-2007 02:37 PM |
More voices in this new PT LE 7.0 ??? | MMC | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 59 | 09-27-2005 01:19 AM |
Voices,Voices,Voices..How to do it!? 002?MBox?HD? | TheMadStudent | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-07-2005 09:16 AM |
G4 PB and 6.x LE. How many voices? | tlester | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-07-2004 04:41 PM |
64 voices w/HD 2, PT 5.3.1 ? | Jonathan Gordon | Pro Tools TDM Systems (Mac) | 1 | 10-08-2003 08:18 PM |
