Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 07-28-2005, 10:07 PM
travmac travmac is offline
Default 6101 & 9128 errors on M-Powered 6.8r2
I was wondering if anyone out there has just installed 6.8r2 and are encountering CPU overload errors (6101 & 9128), even though the buffers have all been set correctly and CPU limit is running at 85% ? I've imported one mono audiofile into a session but the error message comes up after about 3 seconds of playback.
Old 08-04-2005, 10:23 AM
DigiTechSupt's Avatar
Default Re: 6101 & 9128 errors on M-Powered 6.8r2
Please provide more information about your system - computer model, OS version, attached peripherals, etc.
The more info you can provide, the easier it is for us to troubleshoot.
Avid Audio Tech Support
Support FAQ
Old 08-07-2005, 02:19 AM
Using Powerbook G4, 1.67MHz, 80G HD, 2G RRAM, 200G Lacie Ext HD, M-Audio Firewire 410, OS X-Tiger. Have since found that Fierwire 800 drives have not been tested with M-Powered so am trying another firewire 400 Ext HD. Pro tools seems to work fine using the system drive although I know this is not recommended.
Old 08-08-2005, 04:54 PM
robbanks robbanks is offline
I'm having the exact same problem. I initially installed pro tools m-powered yesterday. It worked fine on the system drive. The sample session played without issue. Today I set up my external audio drive, moved the sample session there, along with another tutorial lesson and I'm getting the cpu usage message within a few seconds. Has there been some resolution to this? I'm using a lacie 320GB hd as well. It is a firewire 800 capable drive. Has anything been figured out with this problem?
Old 10-12-2005, 03:23 AM
Yep, all I know is that PTMP 6.8r2 hates firewire 800. Now using firewire 400 drive and system performs well. Wish they'd iron out the 800 problems though - If I'd wanted to use the 400 port I'd have bought an iMac not a powerbook.
10.3.8 and 6101 / 9128 errors Muzoid Pro Tools 10 3 01-27-2014 05:23 AM
Several 9128 and 6101 errors mdiazbass macOS 10 01-02-2013 01:19 PM
PT 10 6101 and 9128 errors spaceman macOS 13 03-12-2012 02:03 PM
9128 6101 errors Scotauto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 04-13-2009 10:07 PM
6101 AND 9128 ERRORS LUISMI 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-09-2008 06:24 AM
