Old 11-05-2010, 08:29 PM
Picture Start Picture Start is offline
Default Master Faders and MC Control in PT9
I have been using a Command 8 for years but am thinking about purchasing the MC Control and Mix now that Eucon is a reality.
The one feature I would find it hard to live without is the Master Faders button on the Command 8, which instantly banks to your master faders in your PT session. Does anyone know if the MC Control can be programmed to do this?
Otherwise you're banking a lot.
Old 11-05-2010, 11:11 PM
Dog and Pony Dog and Pony is offline
Default Re: Master Faders and MC Control in PT9
If the Eucon implementation is anything like it is for Nuendo you can assign any fader to be your master fader and it will always be at your fingertips. Or set that up as a layout and recall it with a single button press.
John McClain
The Dog and Pony Show, Inc.
Dogandponystudios.net
Old 11-06-2010, 12:16 AM
Default
That sounds pretty appealing.
Old 11-06-2010, 02:38 PM
There's sadly no mention of "Direct Assign" features or the ability to permanently assign a fader to a fader in any of the downloadable docs I've been able to find on either site.
Old 11-06-2010, 07:38 PM
Fidelis Fidelis is offline
you can assign any fader to be your master fader thru Eucon software. Or set that up as a layout In Protools and recall it with a single button press! Also it's easy to bank the faders to either home (first track) or end (last track).
http://www.ricardomosca.com
Intel Mac Pro 12 core 3.33 GHz, 20GB RAM, OSX 10.10.5, PT HDX, PT 12.8, SSL 4040G+, tons of outboard
Mac Book Pro 2.4Ghz Duo, 4GB RAM, OSX 10.10.5, PT Vanilla 12.8
Old 11-07-2010, 04:01 PM
The layout things sounds like it'll work. I have on average 6-8 master faders so just one will not do.
Old 11-10-2010, 11:54 AM
DanielEUCON's Avatar
DanielEUCON DanielEUCON is offline
yes - layouts and direct assignments will do this.
You can create surface button that recall your "Masters" layout.
If you need more than 4 faders for Masters, then you may want to think about adding an MC Mix.
Old 11-10-2010, 12:03 PM
Outstanding. Yes, I'm planning on the MC Mix.
Old 11-10-2010, 12:18 PM
Just ordered one of each.
Old 11-11-2010, 01:45 PM
jacko's Avatar
jacko jacko is offline
Are those layouts stored with PT session?
UAD Apollo x16,
UAD Apollo Twin Duo,
UAD Octo Thunderbolt,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
Arturia Beastep for DAW control,
Former Pro Tools HD user (from V7 until V12.6).
Master Faders nate9 ICON & C|24 24 01-20-2009 02:11 PM
How master faders do you usually run? cary chilton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 11-29-2006 01:54 PM
Are master faders really necessary??? AppleFunk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 22 01-30-2004 04:54 PM
USING MIDI FADERS TO CONTROL PRO TOOLS FADERS.... domsound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-08-2004 07:06 PM
Master faders and DSP Psonic Psunspot Tips & Tricks 1 12-23-1999 01:51 PM
