Old 10-12-2008, 11:28 AM
Mr.O Mr.O is offline
Default Midi timing
made an arrangement in PT 7.4 and the same with Logic 8.02 - very interesting!
the timing with playing Midi and VIs in Logic is much better than in PT.
You get a springy, elastic feeling in L8
Then I used plogue bidule in PT, it´s a virtual VST rack with rewire, that you can use with PT
and wow: on a rewire bus battery 3 rocks a lot more than being a RTAS plug
digidesign will say, "that´s the problem with Native Instruments, but I think, this isn´t true, because AIR instruments like xpand or strike have the same
tiring groove
Hope, this problem will change in PT 8
On the other side I am a big fan of PT
Mr.O
Old 10-12-2008, 01:56 PM
shanabit shanabit is offline
Default Re: Midi timing
For me, the HIGHER the BUFFER, the WORSE the TIMING !!!!!
Been this way since Protools 6.0 here. I wish theyd just allocate a certain amount of memory that dealt with JUST the midi so it wouldnt go all over the place.
Logic still has the best midi timing yet.
MacPro 8 Core,2.4, 14 Gig Ram.
OSX 10.8.2
Old 10-12-2008, 04:53 PM
brianstoner brianstoner is offline
Same here.
Midi timing in Logic is excellent and mix sounds tight.
PTLE 7.4.2 timing is all over the place. Frustrating indeed.
PT 8 i am guessing will have the same midi timing issue.
Old 10-12-2008, 06:38 PM
For Recording, lower the Hardware Buffer Size, for Playback set the H/W Size back and use MIDI Track Offsets.
filosofem
Old 10-12-2008, 07:09 PM
Setting up a MIDITRACK OFFSET in 2008!!!!!!
Midi has been going since 1983 and DIGI cant keep the timing on tight??
No thanks, Ill use Logic or Cubase for MIDI
OSX 10.8.2
Midi timing in PT =>6.0 Zeus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-26-2003 03:36 AM
MIDI Timing on PT LE DooDooDoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 25 09-02-2002 10:54 AM
001 midi timing/midi clock/MTC...any probs? Adam Inglis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-01-2001 09:33 AM
MIDI to CV midi timing ??(kenton) any good ? sandman MIDI 1 04-21-2001 06:36 AM
Midi timing on 001 who 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-11-2000 08:50 PM
