Eureka prom installed but the exp pedal wont calibrate right
Everytime i try to calibrate them it just screws em up. they both go to 0 with the toe up, but as a slowly move it foward it jumps to about half way.
Why would this be? |
Re: Eureka prom installed but the exp pedal wont calibrate right
did follow the instructions correctly?
Eureka Sound 11Prom v1.3 - Calibrating Expression Pedals - FCB1010 - Eleven Rack That video was made for the 11 Prom, but its the same process for the EurekaProm. If you are still having problems, then you probably need to adjust a part of the pedals. I think there are instructions on the EurekaSound website.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
try looking at these posts
http://duc.avid.com/showpost.php?p=1786297&postcount=4 http://duc.avid.com/showpost.php?p=1786832&postcount=10 http://duc.avid.com/showpost.php?p=1766510&postcount=25 Full thread: http://duc.avid.com/showthread.php?t=299783
Thanks benoni your always such a big help! I did the calibration and it still happens. Ill try opening it up when i get home.
A small percentage of FCB1010's have a misaligned expression pedal circuit. This webpage discusses it and has photos: http://www.el34world.com/Misc/Music/FCB_1.htm
If the LED & Photodetector are not aligned you could experience the problem you are seeing. Just "mess" with them a little, and the problem will go away. Cheers, Dave www.eurekasound.com |
Free FCB1010 Eureka! PROM | cage77 | Eleven Rack | 1 | 11-10-2013 03:41 AM |
11R with FCB1010 & Eureka Prom | rexrandom | Eleven Rack | 1 | 10-12-2013 02:41 PM |
I have no idea how to use fcb1010 and eureka prom | mesaman4 | Eleven Rack | 2 | 03-07-2013 08:24 PM |
Trouble with eureka prom when using volume pedal | Peter Kroner | Eleven Rack | 4 | 03-06-2013 04:20 AM |
Eureka Sound Prom question | texasdave | Eleven Rack | 2 | 07-23-2012 01:30 PM |
