Old 01-22-2003, 03:29 PM
fingerz88d fingerz88d is offline
Default USB MOTU Micro Express midi problems w/001 & DP 867 Mac: Help!
I just switched over to a new DP867. I'm using a MOTU Micro Express USB midi interface. The MOTU driver is in the system folder, the MOTU USB extension is on, all midi menu items needed are enabled. I never had a problem before, but now I can't get midi in or out of a Pro Tools session. I checked all cables and connections, I'm going directly to the back of the Mac USB input...The Micro Express itself works (when "merge all" is selected, my keyboard controller does indeed drive my other devices, showing the midi flow is flowing, just not thru Pro Tools' session) fine.
What am I missing? Anyone have a clue? Thanks for any help, 'OL 88'
Old 01-22-2003, 05:40 PM
Default Re: USB MOTU Micro Express midi problems w/001 & DP 867 Mac: Help!
up
Old 01-22-2003, 07:41 PM
mgbasinski mgbasinski is offline
do you have OMS installed? If not, that is probably the way to go. If so, can you get to your devices and controllers in OMS studio setup test mode?
Mark
iMac G5 2.1Hz /1.5 GB Ram
OS X 10.4.10
MBox/PT LE 7.4
Reason 3.0.4
MOTU 828
Logic Express 8.0.0
Garage Band 4.1
Old 01-22-2003, 08:04 PM
Thanks, but yes, I have OMS installed. I've been successfully using midi with Pro Tools since LE was first released, and OMS since my Opcode days.
I did a search and discovered I may not have the OMS emulation mode turned on in MOTU's Free Midi.
I'll have to take a look at that when I get back to the studio tomorrow.
Thanks for the reply!
'OL 88'
MIDI dropouts in PT 9 HD / MOTU Micro Express innerbooty MIDI 0 03-07-2013 01:21 PM
MOTU Micro Express question thornlab 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-31-2003 04:59 PM
Midi filter and Motu Micro express!!!! esonus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-02-2002 03:26 PM
MIDI problems with my DIGI and MOTU EXPRESS XT Kanzyani 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-23-2001 07:42 AM
MIDI Output to MOTU Micro Express rnygren 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-12-2001 06:54 AM
