Old 05-16-2019, 06:00 AM
bartosz idzi bartosz idzi is offline
Default 2019.5 Different Disk Cache behaviour (depends on Parallel Task Optimizations)
I noticed that 2019.5 caches audio differently than 2018.12. Previously all was cached into memory as soon as the session was opened, now it seems it caches as i reads into the project. Did anyone notice the same?
EDIT: I found the culprit. It is intended behaviour.
Depends on Parallel Task Optimizations setting. The higher you set it, the less PT cache in advance.
Could not allocate memory for the disk cache. Try lowering your disk buffer.. slim_shady Pro Tools 10 15 05-09-2017 05:20 PM
PT11-Disk Allocation Behaviour? VRW Tips & Tricks 1 02-08-2014 07:34 AM
Disk Cache Bug in PT 10.3.3 zion Pro Tools 10 51 03-12-2013 04:26 PM
PT10's Disk Cache or RAM Disk. Why not use the same concept for VI memory space? sunburst79 General Discussion 6 09-15-2011 11:28 AM
