Old 10-29-2008, 12:58 PM
msb212 msb212 is offline
Default Help: PT's MIDI Clock doubles external devices' BPM
Sometimes my Triton/Dr.Rhythm/Microkorg sync up without a problem to the Pro Tool's master clock. Once in a while...
I set PT bpm to 140 for example, and hit record, and the Triton sequence starts playing at 280 bpm. Can anyone explain what might cause this?
Thanks
Old 10-29-2008, 02:13 PM
DigiTechSupt's Avatar
Default Re: Help: PT's MIDI Clock doubles external devices' BPM
It sounds like you may have a MIDI loopback - is the device set to echo it's input back to it's output? Do you have 'local control' turned on? If so, disabling those will likely fix the problem.
A quick test would be to disconnect the MIDI cable going to the IN on the device in question - if it plays back at the proper speed, you'll know one of the above situations is the most likely culprit.
Avid Audio Tech Support
Support FAQ
Old 11-03-2008, 05:38 PM
I see, so local on is the culprit. Ok, thank you.
Did HD IO output clock to external devices? Rockman413 Pro Tools HDX & HD Native Systems (Mac) 3 07-06-2012 08:41 AM
Problems with external MIDI devices and Pro Tools 8 Lac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-08-2011 09:44 AM
Control external midi devices from Protools Dozerbabar MIDI 2 01-02-2011 03:24 AM
MIDI devices (external/plug-ins) produce no sound KAJ31 MIDI 3 11-02-2006 11:03 AM
Devices Don't show up in Midi Beat Clock Menu LKing MIDI 2 02-12-2003 03:35 PM
