Easiest way to check a plugin's version number under Win 10(?)
I'm sure the answer to this is really simple, but for the life of me, I can't figure it out right now.
On Mac, all I have to do to see a plugin's version number is navigate to the plugins folder, right click on any plugin and choose 'get info', and then all the relative info is listed, including version number. Under Win 10, if I navigate to the plugins folder, right click on a plugin and choose 'get properties', I get some of the relative info, but not the version number. If I instead go to 'programs and features' (where you would normally go to uninstall stuff), and then click on a plugin, the version number is there... which is fine, I guess, but this window is literally all of the programs on the computer (in alphabetical order), which makes it kind of a pain to check plugin compatibility when you're having to sift through a ton of other stuff. Am I missing something? Is it possible to sort programs in 'Programs and Features' so that all the AAX plugins are bundled together? It doesn't appear to be possible to add 'Version' to the details bar in the plugins folder (like it is in the 'Programs And Features' folder), which seems silly, but I'm somewhat new to the Windows file/folder architecture. Is this just how it is on Windows?
PC workstation: Windows 10 Pro i7 12700K RTX 2080ti 64GB DDR5 5200mhz RAM 2 Samsung 980 Pro 1TB SSDs Samsung 850 Pro 1TB SSD LG 34" Ultra-Widescreen monitor Pro Tools 12.4 A loaf of bread A stick of butter A lot of rye whiskey |
Re: Easiest way to check a plugin's version number under Win 10(?)
To to the plug ins folder, find the EXE file and right click. Properties, details. That's the version number.
You can also go to the control panel, programs and features and listed in the far right, there is a version number but that is just the installers version number, which isn't always the same as the exe version number. Most times it is tho.
Brandon Howlett Vibe Audio Post, Inc. Re-recording Mixer Custom Build CPU, HDX 1, Omni, 192 I/O Digital S6 M10 24 fader Satellite Mac Pro, HDNative, 192 I/0 Black Magic HD Extreme |
And you can sort Programs & Features by Name, Publisher, Installed On, Size or Version, by clicking on any of these headings. Works similarly in any Folder.
Well, yeah sure... but that doesn't really separate all the .aaxplugins from the rest of the programs on the drive. Might make it a little easier, I guess, to have them grouped by publisher, but you're still having to sort through non plugin programs. And it does not appear that all the same sort options are available across all folders, because like I said, the option to show 'version' in the details bar doesn't appear to be available in the plugins folder.
You need to go inside the AAX folders to find the plug code. In the drop-down menu at the top of the window you can right-click and choose file version as a column to see it Not all developers do this but many do.
Bob's room 615 562-4346 Interview Artists are the gatekeepers of truth! - Paul Robeson |
Right on Bob, thanks. I tried the 'file version' thing on a few plugins yesterday, but the field was never populated. Even drilled down all the way to the lowest level (the AAXPLUGIN file itself) and nothing. So I'm going to give up on this and ask a better question: How do you guys go about making sure you've the latest plugin versions under Win 10? cheers all
I do it from the programs and features. You say you don't like it, but all your plugins are listed right there in a row. There is literally no faster way. Far quicker than navigating through folders, navigating to files, right clicking, etc. They are just listed right there in alphabetical order and requires no clicking or navigating.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
Wait... what are you sorting by that all the aax plugins are right in a row? The best I can do is to sort by publisher, which at least puts all my Arturia stuff together, and my waves stuff together toward the bottom, etc., but it's still in a sea of other stuff from Adobe, Canon, Microsoft, RME, etc.
If I were able to sort in a way that allowed me to put all the plugins right in a row, that'd be fine with me. I tried adding 'location' to the details bar, but not all of them even have a location listed.
Artist Control check EUCON version on page 74 | Audioartist | Artist Series | 1 | 04-18-2013 10:29 AM |
Check the box before buying Fast Track Version of PT Essential! | bilco | Pro Tools SE and Essential (Mac) | 14 | 02-09-2010 05:50 PM |
002R - How to check firmware version?? | silence2-38554 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-07-2009 06:04 PM |
How to check for PT version ? | LixiSoft | Pro Tools M-Powered (Win) | 2 | 10-01-2006 09:34 AM |
plugin users..check this out! | Nobita | Tips & Tricks | 13 | 12-19-2002 08:45 PM |
