i/o settings
How do I get back to the default Pt9.0.3 i/o settings? I changed hard drives and now the i/o is whacked. Using 003 rack
thanks Baker
Guitarboy's instructional DVD 'Guitarboy Blues & Rock Guitar Workshop' is now available on guitarboy.com |
Re: i/o settings
This happens a lot when you open a session that was started on someone else's setup. Sounds like its time for you to learn that detail. Customizing the IO setup can really streamline your work flow and its worth doing(it won't take long). Since you have PT9, there is a check box to not let a session overwrite your IO setup. Start by going to Setup>IO and start with the output tab(less to do). You could hit the default button(if you're lazy or in a hurry), but let's get detailed. I would click on the first output path and hold SHIFT while you click on the last path, and then hit the Delete Paths button and start over. Add the number of paths you need(maybe you only need a single stereo output, or maybe, like me, you need some headphone paths). Double-click each path to name it, and click the proper boxes in the grid/matrix. Now go to the input tab. On this page, you can add/remove stuff(if you don't have a lightpipe preamp, then you don't need 9 thru 16 at all). Once again, you can name you inputs(I have mine named for the preamp or instrument that is normally patched there). I would then go to the buses tab and scroll down looking for anything in italics. I just uncheck the checkbox next to anything in italics as it is not a working path(PT9 does this sometimes). Once you get each tab set how you want, choose Export and save with a sensible name like "yourstudio_IO". Next time something overwrites your IO, you can open up the setup page(any tab) and select IMPORT and call up your settings(if you end up with both your IO, AND the odd stuff that you started with, so just highlight and delete the duplicates).
Re: i/o settings
LA-610 MK II settings | amayhem | General Discussion | 3 | 11-05-2009 06:12 PM |
Preference settings settings | stainless | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-24-2009 03:35 PM |
Pro tools click settings (1/8 notes or 16th note settings )? | TREBLEBLEED | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-19-2008 09:59 PM |
Cannot save plug-in settings to Root Settings folder | SimonORorke | Pro Tools M-Powered (Win) | 1 | 01-18-2008 08:38 PM |
Settings on the toy Im about to get. | optymusblu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-27-2003 06:02 PM |
