Old 09-06-2009, 12:57 AM
JJ McG JJ McG is offline
Default PT Unexpectedly Quits while/during launching-wtf?
I am running Pro Tools 8 HD - on a Power PC G5 with tons of RAM. Been running great for months. Recently installed BPM - then melodyne plugin, but have repaired permissions, trashed DIGI Databases, and Pro Tools will not start up! It starts launching...connects to the 192, then quits. Please help!
Thanks
McG
Old 09-06-2009, 03:38 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: PT Unexpectedly Quits while/during launching-wtf?
Thanks
McG
Try removing bpm from the plugins folder and place it in the plugins unused folder! system drive/library/app support/digidesign/plugins(and unused plugins folder) and now try launching PT
If no try the same with melodyne plugin.
Make sure all plugins are up to date!!! any out of date or incompatible plugin will cause this.
here the troubleshooting thread..
http://duc.digidesign.com/showthread.php?t=240754
Chris
Producer, Engineer,
www.ukmastering.com
Old 09-06-2009, 09:58 AM
Hey Chris,
YOU RULE!!! It worked! Thank you so much. I trashed prefs - no luck, but BPM had an update, I installed it, and presto! Back up and running. I think that was the issue. Sincerely, thank you for getting back to me. I have so much to do over the next few days, and there is no tech support until Tuesday because of the holiday on Monday. You are a savior!
Thanks again
MCG
Pro Tools 9 wont start! Quits unexpectedly.... Quits during startup... dbC4G Pro Tools 9 11 03-09-2012 07:23 AM
Pro tools 8 LE (just installed) quits unexpectedly during launching Gate 13 macOS 7 07-05-2011 05:58 PM
Protools 6.7 unexpectedly quits b4 even launching caipo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-30-2005 11:41 AM
PT "unexpectedly quits" when launching jermpsf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-20-2005 04:07 PM
Quits Unexpectedly? tromba 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-14-2004 06:56 PM
