Re: Getting Pro Tools to recognize USB-MIDI Interface - Setup
Image of MIDI coming in on Chan 1 I did arm the track, but no dice |
Did you get a signal on the Virtual Instrument or midi track or is it only darkness? Also make sure Midi Thru is enabled under options I think in PT.
Best Regards Christopher #thestruggleisreal ————————————— South Side Music Group WEBHOME ————————————— |
ha! All good, I deserved it!
MIDI Thru is checked |
There is a difference in terminology when using external MIDI keyboards. Your USB connector is a MIDI ‘interface’. You connect the keyboard as a MIDI ‘device’ to a MIDI ‘interface’. You have not created that relationship in AMS. Try creating a new device XP-60 in AMS and make the connections in AMS with the up/down arrows on the bottom of the ‘interface’ to the top of the ‘device’. Then the device XP-60 will show up in PT. Old school MIDI.
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
#16
#17
I have always set up old keyboards and rack devices that way in AMS and they worked. Never tried direct via an interface port unless the keyboard had its own USB connector.
#18
I used to use usb (off keyboard) to computer and get PT to detect it inside the software- always worked but i recently in the last year moved to one of these https://www.sweetwater.com/store/det...midi-interface
Midi latency is a real thing and this device helps out tremendously
#19
I then tested it, and the XP-60 was getting signal and was successful. Went into PT and set up two different Instrument tracks like this: Armed them and hit keys on the Roland XP-60, and nothing. This is so frustrating. I've never had this much issue getting MIDI set up. Regardless I've never used a USB Interface, but all signals point to it working. What the heck? |
#20
PT will not recognize my MIDI interface [SOLVED] | JMUMRD | MIDI | 3 | 05-19-2015 04:17 AM |
Pro Tools won't recognize interface. | wedgewedge | Pro Tools 10 | 3 | 04-30-2014 11:55 PM |
Pro Tools 9 HD won't recognize my 192 interface | innerbooty | Pro Tools TDM Systems (Mac) | 12 | 11-17-2013 01:39 PM |
PRO TOOLS 10 + HD2 + 96 IO interface not recognize | eliomusik | Pro Tools TDM Systems (Mac) | 14 | 09-28-2012 11:34 AM |
Audio/midi setup doesn't recognize my mbox 2 academic? | jpp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-11-2009 10:49 PM |
