Re: Still struggling with MIDI
thanks for your answers. I have a support ticket at Avid now to solve the problem but didn’t get it working so far. To make it clear: MIDI input works in some sessions but not in all. Some sessions don’t get any MIDI, no notes on a MIDI or Instrument track and no sound from instruments. Even if I import a track via Session Data Import from a session where MIDI works. It confuses me that MIDI seems to be Session dependent. Test mode in Audio-MIDI Setup works as well. Best regards Mark
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate |
just to give a quick update: Even Avid support hasn’t found out what the real problem is: They say I have obsolete gear in my MIDI chain (Emagic Unitor 8). That’s true but all new sessions are working, it’s some older ones created on different systems that have problems. I conclude there are session dependent settings for MIDI. I always thought the MIDI setup is a global preference.
In the Setup menu some of the MIDI Setup items are greyed out until you have a session loaded, so those may be session dependent. One of them is MIDI Input Devices - have you looked there?
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
No I didn’t. But thanks for the info I will take a look at it later today.
Best Mark
Another (stupid?) suggestion:
Are you viewing "Instruments" in the mix or edit window? And are they definitely on and not set to "none"? http://duc.avid.com/attachment.php?a...1&d=1552643851 I've had plenty of instances where the session has saved fine, and then for literally no reason the instrument is set to "none" when it re-loads. (This issue still isn't fixed...) |
#16
Mark:
Do you have the current driver installed for the Unitor? See here for it: https://support.apple.com/kb/DL991?v...S&locale=de_DE |
#17
I use MIDI a lot in Pro Tools and have this (or a similar) problem on occasion. For me, it's always the keyboard controller that needs to be rebooted. I've had this experience with multiple controllers over the years – they seem to start kicking out faulty sys ex or something. Worth a try.
New user and struggling! | fraserjoyce | macOS | 3 | 02-16-2016 01:52 PM |
really struggling | mark.jnes | Pro Tools M-Powered (Win) | 3 | 01-18-2006 05:33 PM |
really struggling | mark.jnes | Pro Tools M-Powered (Win) | 0 | 12-17-2005 01:45 PM |
Struggling - is this possible? | protein | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 09-14-2004 07:19 AM |
struggling for I/Os | wlldeans | Pro Tools TDM Systems (Mac) | 0 | 11-03-2003 03:31 PM |
