Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | S3
Old 03-13-2017, 02:58 AM
made made is offline
Default Can the S3 Talkback be improved in 3.6
Welcome to the Forum Eddie,
good to hear that something is happening in the S3 Universe...
In the advent of a Eucon update I want to ask for a very little feature.
Right now, I'm using the internal audio of the S3 for Talkback. Everytime I turn on the S3 I have to unmute the main out. That is not ideal.
Can we have a preference setting fot that?
Thanks!
i7 3,39GHz, 32GB, PTHD2018.12, OS 10.12.6, S3, Transport, (EuCon 19.5.1.44)
LIO
AJA XT-Express
Reaper 5.97, Fireface UCX
MacbookPro i7 PTHD2018.12 10.12.6
Old 03-13-2017, 02:22 PM
EddieJones's Avatar
Default Re: Can the S3 Talkback be improved in 3.6
I think for most having it start up muted is desired and a safety feature.
Old 03-14-2017, 02:29 PM
That's why I think there should be a preference setting...
If you use Talkback, the assigned Outputs can't be used for Monitoring.
Another solution would be to give the option to send the TB Input via AVB to Core Audio.
My guess is that most S3 users don't use the monitoring section anyway. Like on the ProControl. But the ProControl had a seperate TB output...
I just checked the manual. It doesn't say anything about setting up Talkback.
What's the intended workflow?
LIO
AJA XT-Express
Old 03-14-2017, 04:10 PM
mattrixx mattrixx is offline
Hi made,
I notice you are using the Fireface UCX. Why don't you use the talkback feature in Totalmix. Although, there is no specific remote for the UCX, I'm sure you could assign it to a key command.
I currently use Totalmix with the UFX and I've modified my ARC Remote to have a foot switch for the 'A' which isa signed to talkback.
I too don't use the monitoring section of the S3.
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
Old 03-15-2017, 12:31 AM
Hi mattrixx,
thanks for your input.
My UCX is my mobile setup. So no permanent solution...
I want to keep my control room as simple as possible, so I don't get calls when I rent it out...
LIO
AJA XT-Express
Old 03-15-2017, 03:39 PM
You might consider automatic talkback I got so tired of "producers" that couldn't grasp the concept of "push this to talk, or the talent won't hear you" so I automated the whole thing. I have a mic on my desk, one on the ceiling in the drum room and a 3rd on the wall in the tracking room(Crown PCC-160's) and all 3 come in on 3 mono AUX tracks. On the AUX tracks, I insert an EQ(high-pass)>Compressor>Mute-o-matic(freebie from Sound Radix). All feed all headphone mixes and the main out(except CR track is set for no output). When playback is stopped, everyone can converse. As soon as transport starts, all mics are muted
Old 03-16-2017, 04:27 AM
there are tons of possible improvements for the S3.
Auto Talkback and two mic inputs for Talkback would be good as well...
I just don't want to sound greedy...
Here's a lot more....
http://protools.ideascale.com/a/idea...ampaigns/14999
LIO
AJA XT-Express
Source Talkback AAX gets auto talkback MIKEROPHONICS Post - Surround - Video 0 11-20-2013 08:15 AM
PTHDN 10.3.7 Much Improved Trak Pro Tools HDX & HD Native Systems (Mac) 4 08-20-2013 10:41 PM
TL SPACE TDM 1.1.0r9 was improved. K.I. Pro Tools TDM Systems (Mac) 0 02-20-2005 08:14 PM
What would you most like to see improved in PT? pk_hat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 06-02-2003 09:52 AM
Improved mix bus sound in 5.3.1? Superclock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 11-06-2002 03:59 AM
