Old 12-09-2020, 07:26 AM
smj smj is offline
Default Using two digital i/o (HX Stomp & Lynx Aurora)
Hey folks,
Running PT on Windows 10. I have a lynx aurora 16 using AES connections. I also use a Line 6 HX Stomp with a USB connection.
The issue I'm having is if I have the HX Stomp plugged in via USB, protools is outputting all the audio back through the Stomp. That's great for some situations, not for others.
Even though I set the track(s) output to the Lynx Aurora, it doesn't end up there, it just outputs to the HX stomp.
When I click "interface" in the track, the Lynx Aurora shows up, but not the HX stomp. My understanding is I should see an additional 8 channels of i/o with the Stomp as it allows me to send a direct signal to another track. Currently, it's not giving me that option.
Any thoughts?
Sean Meredith-Jones
seanmeredithjones.com
Old 12-09-2020, 09:23 AM
Default Re: Using two digital i/o (HX Stomp & Lynx Aurora)
My thoughts:
1-Open Hardware Setup and select the Lynx as the "Audio Engine"(I bet its set to the HX Stomp at the moment)
2-There is no way(on Windows) to get both units to work at the same time. You will need to choose one or the other.
3-personally, I would disconnect the Stomp USB and connect it via analog connections(or use the USB connection for connection to the Line 6 editing software)
Old 12-09-2020, 09:43 AM
smj smj is offline
Thanks for the response. To each of your points:
1) I think I tried that already and it didn't solve the issue. I'll try again though
2) I think you're right. Someone else in another forum told me something similar as there is no way to create "aggregate" audio devices in Windows out of the box. They sited 3rd party applications that might help.
3) I was doing that initially and couldn't figure out why I was hearing two signal paths. When I disconnected the analog connections, pro tools was still seeing signal and I realized the USB was connected and carrying audio.
I want the USB at least for the HX Edit control... but I have to do some muting in pro tools so I don't hear the analog and digital inputs at the same time.
I'll have to figure out how to mute USB audio signal output in the HX Stomp so I can at least just use it as a remote. I know it would forego the option of outputting direct signal at the same time.
Sean Meredith-Jones
www.seanmeredithjones.com
Digidesign 192 Digital and extra Digital Card Ryan Kelly Buy & Sell 4 06-16-2017 04:48 AM
Power consumption of the 192IO Digital and HD IO Digital Alécio Costa Pro Tools TDM Systems (Mac) 32 10-26-2014 10:55 PM
Newbie Digital IO question - HD Digital i/o vs 192 Digital vs X-HD mrdosun Pro Tools 10 1 02-16-2012 11:20 PM
If I get PTHD can I hang all my 44/48k digital gear off of a 192 Digital I/O? Jules Pro Tools TDM Systems (Mac) 11 06-21-2002 06:57 AM
Digital Output from 888/16 isn't compatible with Digital Input of TC M2000 & PCM 80 beerbr Pro Tools TDM Systems (Mac) 0 11-02-2000 08:01 PM
