Mbox 2 Micro compatible with PT11?
According to this Avid compatibility page, the Mbox 2 Micro is supported for PT11.
I've installed PT 11.3.1 Win84152 and Mbox Drivers v90625. My Mbox 2 Micro works perfectly with PT10. I can go to the "Playback Engine" and the Mbox 2 Micro is listed with multiple H/W buffer sizes up to 1024. Playback runs through the Mbox 2 Micro as expected, ie, I can hear it with headphones in the Mbox 2 Micro port. Open PT11... It's not an option in the Playback Engine. I only have Mbox 2 at 256 H/W buffer. If I proceed with that and open a session, it doesn't playback through the Mbox 2 Micro. Any suggestions? Need a Sandra report?
____________________________________ Home Build: Core i7 920/Gigabyte EX58-UD3R/6Mb Ram Mbox2/MboxMicro ProTools 8.0 |
Re: Mbox 2 Micro compatible with PT11?
Is Windows designating the Micro as a playback device? It shouldn't...
Would that lead to differentiation between PT10 and PT11?
-nope. not that. I disabled it as a playback device with no luck.
Sandra report:
SiSoftware Sandra ID Host Name : MKC_laptop Workgroup : WORKGROUP Computer Model : HP ENVY m4 Notebook PC 103C_5335KV G=N L=CON B=HP S=ENV Serial Number : 6CE23***** Chassis : HP Notebook Mainboard : HP 18EE Serial Number : PCWSRA1******* BIOS : Insyde F.12 10/26/2012 Intel vPro : 8.01.00.1248 Total Memory : 7.9GB DDR3 SO-DIMM Processors Processor : Intel(R) Core(TM) i7-3632QM CPU @ 2.20GHz (4C 8T 2.2GHz, 2.2GHz IMC, 4x 256kB L2, 6MB L3) Socket/Slot : FC PGA988 Chipset Memory Controller : HP Core (Ivy Bridge) Mobile DRAM Controller 100MHz, 2x 4GB DDR3 SO-DIMM 1.6GHz 128-bit, Integrated Graphics Memory Module(s) Memory Module : Kingston HP536727-H41-ELD 4GB DDR3 SO-DIMM PC3-12800S DDR3-1600 (11-11-11-29 5-40-13-6) Memory Module : Kingston HP536727-H41-ELD 4GB DDR3 SO-DIMM PC3-12800S DDR3-1600 (11-11-11-29 5-40-13-6) Video System Monitor/Panel : LGD Generic PnP Monitor (1600x1200, 13.9") Video Adapter : Intel(R) HD Graphics 4000 (16CU 16SP SM5.0 350MHz/1.15GHz, 32MB DDR3 1.6GHz 128-bit, Integrated Graphics) Graphics Processor OpenCL GP Processor : Intel(R) HD Graphics 4000 (16SP 16C 1.15GHz, 1.4GB DDR3 1.6GHz 128-bit, Integrated Graphics) Compute Shader Processor : Intel(R) HD Graphics 4000 (16SP 16C 350MHz/1.15GHz, 64MB DDR3 1.6GHz 128-bit, Integrated Graphics) Storage Devices WDC WD10JPVT-60A1YT0 (1TB, SATA300, 2.5", 5400rpm, 8MB Cache) : 932GB (C:) (D:) hp DVDRAM GU60N (SATA150, DVD+-RW, CD-RW) : N/A (E:) Logical Storage Devices Hard Disk (C:) : 906GB (NTFS) @ WDC WD10JPVT-60A1YT0 (1TB, SATA300, 2.5", 5400rpm, 8MB Cache) RECOVERY (D:) : 25GB (NTFS) @ WDC WD10JPVT-60A1YT0 (1TB, SATA300, 2.5", 5400rpm, 8MB Cache) WINRE : 400MB (NTFS) Hard Disk : 451MB (NTFS) Optical Drive (E:) : N/A @ hp DVDRAM GU60N (SATA150, DVD+-RW, CD-RW) Peripherals LPC Hub Controller 1 : HP Panther Point LPC Controller LPC Legacy Controller 1 : Winbond W83687THF Audio Device : HP Panther Point High Definition Audio Controller Audio Codec : Integrated Device Tech 76E0 Disk Controller : HP Mobile SATA RAID Controller USB Controller 1 : HP Panther Point USB xHCI Host Controller USB Controller 2 : HP Panther Point USB Enhanced Host Controller #2 USB Controller 3 : HP Panther Point USB Enhanced Host Controller #1 SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer v4 (600x600, Colour) Printer : HP ePrint (600x600, Parallel, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : doPDF 7 Printer Driver (2400x2400, Colour) Network Services Network Adapter : Realtek PCIe GBE Family Controller (Ethernet) Wireless Adapter : Ralink RT5390R 802.11bgn Wi-Fi Adapter (802.11n (HT), AES-CCMP, 72Mbps) Power Management Battery No 1 : PegaTron HS1 61.99Wh/4.86Ah Operating System Windows System : Microsoft Windows 8 Home 6.02.9200 Platform Compliance : x64 Windows Experience Index Current System : 5.9
Is the Focusrite Saffire Pro 24 compatible with PT11 | CG Kid | Third Party Interfaces | 4 | 10-10-2014 02:18 PM |
Orchestral VST's compatible w/ PT11 | musiclee | AAX Plug-ins | 15 | 04-06-2014 06:59 AM |
Is Mobile Pre USB compatible with PT11? | bluebe11 | Pro Tools 11 | 2 | 10-16-2013 01:09 AM |
PT11 compatible UA Apollo interface? | djkikis | macOS | 4 | 07-05-2013 07:44 PM |
Will HDX not compatible with PT11? or not the best for Pt11? | Rockman413 | Pro Tools TDM Systems (Mac) | 5 | 10-26-2011 10:00 PM |
