Old 12-13-2009, 07:26 AM
Víctor SP Víctor SP is offline
Default PT 8 Problem Play/Record stop cuts (-6085)
Hello,
I updated to Pro Tools 8 version some months ago, and I have problem:
When its playing or recording the sound stop every a few seconds. Just cuts on -1349
Problem: (-6085)
I found a solution when installing it on a sistem without motherboard´s
drivers. But its no rigth to work.
Digi002, PT8
My pc: XP with a motherborad ASUS P5K.
Víctor.
Old 12-13-2009, 01:49 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: PT 8 Problem Play/Record stop cuts (-6085)
Read the General Troubleshooting thread at the top of the forums and make sure you go through everything suggested there. If still no luck, post a Sandra Report so we can better help you. Good luck
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS Catalina 10.15.7
Pro Tools HD 2020.11.0
Old 12-13-2009, 05:51 PM
Thanks!
I tried the General Troubleshooting, many usefull info, but no a solution yet. I´m still testing. As soon as I get somethig I will post.
Here is my Sandra report, hope its rigth:
Processor
Model : Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
Speed : 2.4GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 1 Unit(s)
Type : Quad-Core
Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size
L2 On-board Cache : 2x 4MB, ECC, Synchronous, ATC, 16-way, 64 byte line size, 2 threads sharing
Computer
Mainboard : Asus P5K
BIOS : AMI 0603 07/03/2007
Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 2GB DIMM DDR2 DDR3
Chipset
Model : ASUS P35/G33/G31 Processor to I/O Controller
Front Side Bus Speed : 4x 267MHz (1GHz)
Total Memory : 22.25GB DIMM DDR2 DDR3
Memory Bus Speed : 2x 401MHz (802MHz)
Memory Module(s)
Memory Module : Golden Empire CL4-4-4DDR2-800 1GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-18 3-23-6-3)
Video System
Video Adapter : NVIDIA GeForce 7300 SE/7200 GS (2 PS3.0, 2 VS3.0 450MHz, 256MB DDR3 2x526MHz, PCIe 1.00 x16)
Graphics Processor
Storage Devices
ST380011A (80GB, ATA100, 3.5", 2MB Cache) : 75GB (C:)
ST3400832A (400GB, ATA100, 3.5", 8MB Cache) : 373GB (D:)
ST3750330AS (313.3GB, USB/SATA300, 3.5", 7200rpm, NCQ) : 292GB (G:)
HL-DT-ST DVDRAM GH20NS10 (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:)
GFKFABW IZS16RKX2 (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R) : N/A (I:)
Logical Storage Devices
ENIGMA (C:) : 75GB (NTFS) @ ST380011A (80GB, ATA100, 3.5", 2MB Cache)
VIENA (D:) : 373GB (NTFS) @ ST3400832A (400GB, ATA100, 3.5", 8MB Cache)
Optical Drive (E:) : N/A @ HL-DT-ST DVDRAM GH20NS10 (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Optical Drive (I:) : N/A @ GFKFABW IZS16RKX2 (SCSI, BD-R, HD-DVD-R, DVD+-R-DL, CD-R)
3.5" 1.44MB (A:) : N/A
Hard Disk (G:) : N/A @ ST3750330AS (313.3GB, USB/SATA300, 3.5", 7200rpm, NCQ)
Peripherals
LPC Hub Controller 1 : ASUS (ICH9) LPC Interface Controller
LPC Legacy Controller 1 : Winbond W83627DHG
Audio Device : ASUS (ICH9) HD Audio Controller
Audio Codec : Realtek Semiconductor 883 High Definition Audio
Audio Device : Terratec Electronic DMX 6Fire 24/96
Serial Port(s) : 1
Disk Controller : ASUS (ICH9) 2 port Serial ATA Storage Controller 1
Disk Controller : ASUS (ICH9) 2 port Serial ATA Storage Controller 2
Disk Controller : ASUS JMB36X PCIE-to-SATAII/IDE RAID Controller
USB Controller 1 : ASUS (ICH9) USB Universal Host Controller
USB Controller 2 : ASUS (ICH9) USB Universal Host Controller
USB Controller 3 : ASUS (ICH9) USB Universal Host Controller
USB Controller 4 : ASUS (ICH9) USB2 Enhanced Host Controller
USB Controller 5 : ASUS (ICH9) USB Universal Host Controller
USB Controller 6 : ASUS (ICH9) USB Universal Host Controller
USB Controller 7 : ASUS (ICH9) USB Universal Host Controller
USB Controller 8 : ASUS (ICH9) USB2 Enhanced Host Controller
FireWire/1394 Controller 1 : VIA VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller
FireWire/1394 Controller 2 : ASUS VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller
SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus
Printers and Faxes
Printer : PDF995 Printer Driver (600x8211, Colour)
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : PaperPort Mono Printer Driver (600x600)
Printer : PaperPort Color Printer Driver (600x600, Colour)
Printer : Brother DCP-7010 USB Printer (1200x1200, USB)
Printer : AGFA-AccuSet v52.3 (3000x3000, Parallel)
Network Services
Network Adapter : Attansic L1 Gigabit Ethernet 10/100/1000Base-T Controller - Minipuerto del administrador de paquetes (Ethernet, 100Mbps)
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 2)
Platform Compliance : x86
Performance Tips
Tip 2546 : Large memory modules should be ECC/Parity.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Old 12-13-2009, 06:05 PM
mykhal c's Avatar
mykhal c mykhal c is offline
Originally Posted by Víctor SP View Post
Memory Module(s)
Storage Devices
number of things jump out at me...
1) is ram timimg set correctly?? usually DDR2 800 ram will have timings of 4-4-4-12...at least the better modules. not sure about your brand. check your specs to confirm.
2) cache sizes on HDDs are very small. tryin' to run PT8 with these specs will 'probably' give problems.
3) the VIA chipset on the ASUS P5K mobo's were/are problematic. i have the ASUS P5K Deluxe with Q6600 proc. when we tested these systems over 2 years ago now, we discovered the problem with the VIA chipset. get a DIGI approved PCI F/W card.
4) if you cannot make any changes to your system from a cost standpoint then go into your playback engine settings and make and test changes to your 'DISK and CACHE' settings.
hope that helps.
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
i7 Builds - Specs and Results
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
Old 12-13-2009, 06:38 PM
Benoni's Avatar
Benoni Benoni is offline
1) is ram timimg set correctly?? usually DDR2 800 ram will have timings of 4-4-4-12...at lease the better modules. not sure about your brand. check your specs to confirm.
3) the VIA chipset on the ASUS P5K mobo's were/are problematic. i have the ASUS P5K Deluxe with Q6600 proc. when we tested these systems over 2 years ago now, we discovered the problem with the VIA chipset. get a DIGI approved PCI F/W.
hope that helps.
+1 all good advice. And to add, i believe Digi now recommends SP3 for XP. Also are you on 8.0.1? you should be if you are not.
Is this on EVERY session of just one or two? Using things like Disk Cleanup will compress your files and make them not play, so if you have done this recently you will need to uncompress your audio and fade files, any compressed files will be in BLUE text. So check your hard drive and session files. And i assume you are recording to a separate hard drive not to the OS drive correct, and not to a USB either.
Brian
Windows 10 Pro 64 Bit
Pro Tools 2020
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Instagram
Old 12-30-2009, 06:22 AM
Hello!
After reinstall the system operative, and start since the begin installing program and drives, I got the solution and PT8 is working perfect!
Maybe start with a clean SO its the best solution when one cant find the solution.
Víctor.
Problem: Play / Stop sluggish to respond HD3 johnsimmons Pro Tools TDM Systems (Mac) 18 03-20-2011 12:24 PM
Hitting Play or Record, blue stop button lights up... delay Monty_python 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 09-06-2009 12:33 PM
odd play/record problem Craig F Pro Tools TDM Systems (Mac) 0 02-21-2007 09:14 PM
cannot record and cannot stop play x9blade Pro Tools TDM Systems (Mac) 2 02-20-2006 05:52 PM
play and stop problem earhythmic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-23-2004 03:17 PM
