Old 09-03-2004, 12:18 AM
ukeist ukeist is offline
Default Patch Bay-Digi002 Questions
I am wanting to simplify my life and set up a patch bay to stop the endless plugging and unplugging. Now I don’t use a console but I was hoping to figure out how to hook the bay to the 002 and have all my mic pres, compressors, etc then available to combine as I like. Any suggestions on the easiest ways? Patch bays are pretty confusing to me. Thanks in advance!
Old 09-03-2004, 06:58 AM
davetron5000 davetron5000 is offline
Default Re: Patch Bay-Digi002 Questions
I get confused with the whole normalled/half-normalled/etc terms, but basically, my patchbay is setup so that the top plugs in the back are default routed to the bottom plugs in the back. Analagous plugs in the front break that chain.
So, I have me pres connected to the top row and then cables from the bottom row to the 002's inputs. So, pres are always connected. But, if I need to patch in a keyboard, I just plug the keyboard out to the FRONT bottom row for the appropriate input, thus break the chain of pre--input.
I also have my keyboard outs to the back top row, and the back bottom row for those goes to my mixer for monitoring during MIDI playback. I can then patch those two from the FRONT top row to my 002 input's (FRONT bottom row) when I need to mix down.
MacBook Pro Core Duo 1.83
2 Gig RAM
OS X 10.4.8
002R/PTLE 7.3.1
Old 09-03-2004, 09:58 AM
Make It Loud Make It Loud is offline
This might help Patchbays.com
G4 9.2
PT 5.1.1 (32 track update)
Triton Rack
AKAI S5000
Yahama DSP1
Mackie Control
Midiman 8
DIGI001
Old 09-03-2004, 03:48 PM
alance alance is offline
What davetron has is a normalled patchbay. This is by far the best way to go. Of course mine isn't normalled. It's cheaper that way, and most of the xlr ones in Markertek and the like aren't. If your patchbay is mostly to clean up a rack or cart and you use Primarily 1/4 " and xlr , it doesnt matter that much, but if you are putting a TT patchbay in a transfer house or studio with tons of gear you'll definitely want to go normalled as you have lots of devices that "normally" go in a chain.
Looper in the Effects Loop (setup) questions. Patch Changing... electricfiddle Eleven Rack 11 12-11-2011 10:53 PM
Digi002 questions hikari 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-30-2009 09:12 PM
ADR with ISDN/ Phone-Patch questions villagesound Pro Tools TDM Systems (Mac) 5 02-09-2005 10:34 AM
PT 6 questions: plug ins and patch names Joseph Anderson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-14-2003 03:18 PM
Digi002: Two Questions nahuz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-26-2002 11:38 AM
