Latency Issues
I am using Pro-tools 8.0.4 and I have a huge latency problem when I record. There is an echo in the headphones. I have decreased the buffer and I have turned down the mix knob on my MBOX 2. ANYONE HELP PLEASE
Re: Latency Issues
are you recording to an external hard drive or to the system drive? this could make a difference (recording to an external hard drive is better!) look in the setup guide for how to properly set the the buffer settings & other related settings when situations like this arise. if you have the pro tools le 8.0 book then it should start at page 26. Read 26-34.
Re: Latency Issues
If you MUTE the track you are recording to, then use the MIX knob to balance your new vocal(or whatever you are recording) with the existing tracks, there should be no echo.
Re: Latency Issues
OK but I am using an external drive to record to. Any other suggestions? Its kinds hard to ride a beat if you can't hear it while recording.
Re: Latency Issues
What book are you referring to? The Getting Started book? Please Help!
Re: Latency Issues
Reread what albee told you... that's the solution to your issue.
Re: Latency Issues
That does work, however can't hear vocals through head phones. Any solutions?
Re: Latency Issues
Turn the MIX knob to the middle. You will hear the tracks AND your incoming vocal.
Re: Latency Issues
Thanks alot for the help. I was getting very frustrated
Latency Issues - changing latency has no effect | Kippa-Dee | Pro Tools M-Powered (Win) | 1 | 07-15-2010 08:39 PM |
Latency Issues, Please Help!!! | daveseviltwin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-19-2010 07:01 PM |
latency issues | stainless | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-23-2009 08:27 PM |
Latency issues | Blindman13 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 03-18-2008 02:20 PM |
LATENCY ISSUES WITH 7.3.1 | KRAFT | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-30-2007 09:23 AM |
