Old 11-09-2010, 06:20 AM
DAR Fritz DAR Fritz is offline
Default Help with Logic and 11r
Hi all-
I recently purchased Logic Express 9 for a project and I'm having problem adjusting monitor levels for the track I'm recording to. I'm using a MacBook with the 11r as my interface and set up Logic pref's core audio as the I/O device and did the same in the Mac pref's. I also selected "software monitoring" and "independent monitoring level" in Logic. The 11r is recognized with Logic and records just fine. The problem I have is adjusting the monitor level for the track I'm recording on. I can't seem to turn the volume down when I record to it. If I use the output of the Mac to monitor bypassing the 11r as the output it works fine but when I use the 11r main outs to monitor I can't turn the track down. Is there a setting on the 11r so it doesn't pass the signal through so I can control the monitor level of the track I'm recording?
Any help would be much appreciated! Many thanks in advance!
Fritz
Old 11-09-2010, 10:13 AM
bender-offender bender-offender is offline
Default Re: Help with Logic and 11r
Originally Posted by DAR Fritz View Post
Hi all-
Fritz
It's because the Eleven Rack will always be outputting the guitar signal (just like when you play through the Eleven Rack standalone) so when you are using any program other than Pro Tools (which shuts off that constant output) you're going to get twice the signal after you record enable the track you're recording to in Logic.
I haven't been able to find an official way around this (I'd like to hear it if there is one), so in the meantime I've either muted the track I'm recording to in Logic or I've setup an aggregate device with another interface and had the Eleven Rack secondary, that way your output is coming from a different source.
Mac Pro 8-core 3ghz, OS 10.6.7, 16GB ram PT 8, Digi002, Cubase 6, Logic 9, MOTU 2408mk3, Eleven Rack
Old 11-09-2010, 11:23 AM
Thanks for the reply. Guess I'll monitor from the output of my MacBook when I track.
Logic 8 to logic 7 session won't open! saving procedure need crizdee Pro Tools TDM Systems (Mac) 9 04-26-2008 08:09 PM
Logic Pro users: Midi & audio between Logic & PT dtmprod Pro Tools TDM Systems (Mac) 4 09-24-2006 04:16 PM
tdm logic plug in automation in logic 7? quincygriffin Pro Tools TDM Systems (Mac) 5 05-23-2005 09:08 AM
Logic 5.0.0 crashes all the time.. Is there a Logic expert around here? uno1234 Pro Tools TDM Systems (Mac) 13 04-28-2002 04:23 PM
Hello Logic users.......Please explain about Logic Midi elik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-04-2001 12:35 AM
