Old 02-28-2018, 01:19 PM
Hanswurstlsepp Hanswurstlsepp is offline
Default Offset after recording audio routed thru a bus
I posted this in Juli 2017 and I'm still having the same problem:
today I recorded some background vocals. Same Setup as always (since years):
2 Mics using two preamps. The 2 outputs of the preamps are connected to Input 1 & Input 2 of my HD i/o.
The two Inputs of the HD i/o are set as input sources of two AuxInputs within PT. The Outputs of the 2 AuxInputs are routed via one mono bus to an audio track so that I can record the two mics as one MonoAudioTrack.
After recording I remarked that the recorded AudioClip had an awful offset (much too late). I tried all kind of trouble shooting, like disabling and re-enabling ADC, changed playback buffer size, disabled dozens of PlugIns ... but no success.
All I could do was to record directly to an AudioTrack without the routing via a bus . Of course I had to use 2 AudioTracks, each set to a different input as I was using 2 preamps plugged into my HD i/o.
Any idea what could have happened and have others seen this, too ?
Cheers, STeff
MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected  OSX10.15.7  Pro Tools|HDX Ultimate 2023.6  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
Old 03-01-2018, 06:44 AM
daeron80 daeron80 is offline
Default Re: Offset after recording audio routed thru a bus
HD has a random latency bug that affects a relatively small number of users. That could be it. Does the same setup sometimes work properly?
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 03-01-2018, 09:35 AM
I tried a couple of times using PT 2018.1.0 and MacOS 10.13.2. The same latency problems happened.
When I boot my Mac from an old BackUp-HD (PT HD 11.1.3 & MacOSX 10.9.2 from June 2014), all is fine !
Cheers, STeff
Old 03-01-2018, 12:18 PM
ZEUSS ZEUSS is offline
You are correct. There is a bug with this situation. I have mentioned it a few times and it was logged with avid for a future fix but it has not been done.
See this pic. Very easy to see that there is delay comp being added for no reason.
Just set up a few inputs and route to a bus. Then route to a print track.
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1
Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX.
Old 03-01-2018, 12:30 PM
YYR123's Avatar
YYR123 YYR123 is offline
///...I tried all kind of trouble shooting, like disabling and re-enabling ADC, changed playback buffer size, disabled dozens of PlugIns ... but no success.
Is the idea behind this workflow to be able to use LLM while recording with plugs?
I am just trying to understand the benefits of doing it this way
Daniel
Old 03-01-2018, 12:48 PM
It should be possible to turn off the delay compensation on the Gtr 1 audio track by ctrl-cmd-clicking (Mac) on the delay comp readout. It should turn grey, like a deactivated plugin. Does that help the situation?
This is definitely a bug and should be fixed, but that may be a usable workaround for the moment if it works.
Scott Gatteño
Old 03-01-2018, 12:49 PM
No - no PlugIns.
Just two or more Inputs which should be recorded onto one AudioTrack - thats all !
Cheers, STeff
Old 03-01-2018, 12:53 PM
...to use LLM ....
What is LLM ?
Cheers, STeff
Old 03-01-2018, 01:01 PM
YYR123's Avatar
Low latency Monitoring
Daniel
Offset after recording audio routed thru a bus Hanswurstlsepp Pro Tools 12 10 02-28-2018 01:14 PM
Routed audio into Pro Tools w/ Soundflower lincol1 macOS 14 04-19-2012 10:34 PM
Audio not routed properly Pais_man macOS 2 02-25-2011 05:31 PM
does Video offset cause audio recording delay? compusic Post - Surround - Video 34 05-25-2010 08:26 AM
Internal Audio vs PT8 routed? thopman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-27-2009 05:24 AM
